mini-ram users, let's see your oil return lines!
Old Feb 26, 2007 | 05:17 PM
PA MATT's Avatar
Default mini-ram users, let's see your oil return lines!
I'm going to be putting my mini-ram on my d16 soon and would like to see what people are doing for oil lines. I'm hoping my oil line will be high enough that I won't have any problems, but just want to see what everybody is doing
Old Feb 26, 2007 | 06:03 PM
Autoworks's Avatar
Default Re: mini-ram users, let's see your oil return lines! (PA MATT)
...digs for pics
first mini ram sat the turbo too low. The return was already welded from my prev. setup (Greddy mani and 15G) I had to loop the return becuase the turbo sat a little lower than the return fitting (T3/T4 50 trim)
New current mini ram, sits the turbo a little higher and more forward, direct oil return
(straight barb fitting comes out the pan)
57 trim...about to be a custom 60-1
Old Feb 26, 2007 | 06:21 PM
PA MATT's Avatar
Default Re: mini-ram users, let's see your oil return lines! (Autoworks)
wow, that's really low!. I hope mine isn't, but I will soon find out.
Old Feb 26, 2007 | 06:37 PM
PA MATT's Avatar
on the second setup, couldn't you have clocked the center section towards the motor more and used a 45 off of it? seems like that would be near perfect
Old Feb 26, 2007 | 09:53 PM
PA MATT's Avatar
looking for more.....
Old Feb 27, 2007 | 04:53 AM
PA MATT's Avatar
anything?
Old Feb 27, 2007 | 05:09 AM
alex_s817's Avatar
bump im interested too
Old Feb 27, 2007 | 05:13 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote">wow, that's really low!. I hope mine isn't, but I will soon find out.</TD></TR></TABLE>
Who made yours?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote">on the second setup, couldn't you have clocked the center section towards the motor more and used a 45 off of it? seems like that would be near perfect</TD></TR></TABLE>
Could have yes, but it's worked great the way it is. That turbo is actually coming off tomorrow and I may change the fitting as well. No problems at all.
Old Feb 27, 2007 | 08:31 AM
PA MATT's Avatar
mine was made by rld-fab. There's pics on this page if you would like to see it
https://honda-tech.com/zero...e=152
Old Feb 27, 2007 | 08:50 AM
Schister66's Avatar
Man U FTW
wow those oil drains sit really low!! Any of you guys have problems w/ that?
Old Feb 28, 2007 | 12:37 PM
PA MATT's Avatar
Default Re: (Schister66)
there have to be more peopl eout there with mini-rams
Old Feb 28, 2007 | 04:27 PM
drintegra's Avatar
Default Re: (PA MATT)
Here was my dilemma
Ended up with this
I had to put a 90 off the turbo and clock it with the drain towards the front of the car to angle it down and towards the pan wit a straight barbed fitting.
Old Feb 28, 2007 | 04:45 PM
B18C1CYA's Avatar
Default Re: (drintegra)
wow your downpipe hangs low
Old Feb 28, 2007 | 06:39 PM
Heylookits shawn's Avatar
Default Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">wow your downpipe hangs low </TD></TR></TABLE>
yea, unless you're throwing that thing in a rock crawler, im forseeing major scrapeage problems
Old Mar 1, 2007 | 10:22 AM
drintegra's Avatar
Default Re: (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">
yea, unless you're throwing that thing in a rock crawler, im forseeing major scrapeage problems </TD></TR></TABLE>
Yeah, that was mocking up, I sent it back to get fixed. It is all good
Old Mar 5, 2007 | 10:46 PM
SLowCrx's Avatar
Here are a few pics of my AFI mini on my d16z6.. I havent welded the fitting on the pan yet but I think I will be ok if I clock the turbo a little bit more toward the front of the car..
Old Mar 6, 2007 | 02:55 AM
CSaddict's Avatar
I have made a lot of mini rams. They always hang a bit low. You are better off clocking the center section and aiming the return at the pan. Here is a top pic if it helps.
Old Mar 6, 2007 | 04:44 AM
PA MATT's Avatar
Default Re: (CSaddict)
im gonna look into getting the function7 flange. it has an -an fitting right off of it. I think if I get that, and run a 45 off of it with the center section clocked towards the pan, ill be doing just fine...time will tell, hopefully this week!
Old Mar 19, 2007 | 08:59 AM
PA MATT's Avatar
Finally got to mocking mine up, sits a lot lower than I had hoped. I might clock towards the front of the car and use a 120* fitting, hoping that will make it. If it wasn't so close to the block, a 45 and the turbo clocked towards the block would have been perfect.
Anybody think it'd be a good/really bad idea to run a 90 off of the drain, and around the compressor?
Old Mar 21, 2007 | 12:37 PM
drintegra's Avatar
I gotta 90 off the turbo and straight off the pan. Have not had issues. I don't like it but gotta live with it.
Old Mar 21, 2007 | 12:56 PM
PA MATT's Avatar
I dont have a 90 right now, but I do have a 45 and it leaves no room for any hose or anything else. Im either going to run a 90 with the turbo clocked to the front or a 120 degree fitting witht he turbo clocked toward the front. Hoping one of these will work
Old Mar 21, 2007 | 05:22 PM
user 98292739's Avatar
slowcrx that looks great! glad everything fits so nicely. I Like how snug the down pipe fits AFI does awesome work.
Drintegra- is it me or is your downpipe really really low? almost like itll touch the ground if your car is lowered.
Old Apr 9, 2007 | 08:58 PM
PA MATT's Avatar
Default Re: (The Lobster)
just an update of how mine looks.....any ideas?
Old Apr 9, 2007 | 09:29 PM
PA MATT's Avatar
pic of the street elbow im using to show how tight it is...
Old Apr 10, 2007 | 06:58 AM
Autoworks's Avatar
just an update of how mine looks.....any ideas?</TD></TR></TABLE>
If at all possible I would try to get the bung in the pan up higher.
