In the middle of install! About to install fuel pump! help!
Old Oct 27, 2001 | 05:28 PM
DIRep972's Avatar
Smarter than you
Default In the middle of install! About to install fuel pump! help!
We are about to get to the fuel pump part of the install on stans(flamenco) car. Its a Drag 3 kit on a GSR and this is the only thing we do not know how to do.. Can anyone give us specific directions on where to mount it and where to hook up the wires? or a link to a page that tells how to do it?
Old Oct 27, 2001 | 05:33 PM
DragII's Avatar
25 Year Member
Default Re: In the middle of install! About to install fuel pump! help! (DIRep972)
I used a relay to hook mine up. relay has 4 prongs
input
output
power
ground
input - hooks to dash lighting, or anything switched on by ignition (5amp fuse here)
output - to fuel pump positive terminal
power - direct from battery (30amp fuse here)
ground - good ground
hope that helps
Old Oct 27, 2001 | 05:53 PM
DIRep972's Avatar
Smarter than you
Default Re: In the middle of install! About to install fuel pump! help! (DragIIcivic)
this is stan(flamenco)
thanks for the quick reply..
are we using a bosch relay ? which one is input, output power and ground ?
I am gonna get my relay in the garage and post here on the tab again..
thanks
stan
Old Oct 27, 2001 | 05:58 PM
DragII's Avatar
25 Year Member
I used a standard automotive lighting 12v relay...should cost 4 bucks.
all tabs were labeled
Old Oct 27, 2001 | 07:20 PM
Arturbo's Avatar
Better than steak
25 Year Member
Chris your dad should have some bocsh relays laying around which cost $.99.
Jamesb223
Jan 21, 2018 08:01 PM
jun10r27
Honda Civic (2001 - 2005)
Dec 15, 2009 08:35 PM
crxb16sir
Dec 14, 2009 09:56 PM
S2kool
Dec 14, 2008 03:24 AM
DOHCarp
Apr 1, 2002 04:40 PM
