mechanical gauge question
Old Feb 7, 2004 | 08:22 PM
b18c1wes's Avatar
Default mechanical gauge question
does anyone make a low psi mechanical boost gauge?.. like 0-15psi (preferably) or 0-20. im running 5-7psi and i can barely keep tabs with my 30psi gauge. i did a search and couldnt come up with anything BTW
Old Feb 7, 2004 | 09:51 PM
Mad Cow's Avatar
Default Re: mechanical gauge question (b18c1wes)
Um, Autometer does. Mine goes 0-30in/Hg - 0-20psi. Look on their website.
Old Feb 8, 2004 | 04:54 AM
b18c1wes's Avatar
tried but i cant find the 0-20psi they all say 0-30 i really want 0-15psi... possible?
Old Feb 8, 2004 | 08:05 AM
Sonny's Avatar
25 Year Member
Default Re: (b18c1wes)
Jackson Racing has one. It's made by Autometer.
Sonny
Old Feb 8, 2004 | 08:16 AM
ClubSiRacer's Avatar
The JR gauge has a very short sweep. I personaly use an Autometer vac/boost gauge with a 20psi peak. It is a full sweep gauge.
Old Feb 8, 2004 | 05:53 PM
b18c1wes's Avatar
what is "the JR gauge has a very short SWEEP"?
Old Feb 8, 2004 | 06:03 PM
MADEINIRAQ's Avatar
sweep.. as in the needle only moves along about half the face.
unlike normal autometer mechanical guages
Old Feb 8, 2004 | 06:30 PM
Matt B's Avatar
Old Feb 8, 2004 | 06:39 PM
Bailhatch's Avatar
Default Re: mechanical gauge question (Matt B)
thats the one I have^
easy to read IMO I like the straight USDM black face look to. They make one with a black bezel which I wish I had, summit is the only place I have found the all black one.
Old Feb 8, 2004 | 06:44 PM
ITSTOCK's Avatar
Default Re: mechanical gauge question (Bailhatch)
Go on ebay and search for boost gauges, ive had 3-4 of the auto gauge boost gauges and they work great, and didnt cost much.
Old Feb 8, 2004 | 07:01 PM
JrCRXHF's Avatar
Default Re: mechanical gauge question (MadCow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow &raquo;</TD></TR><TR><TD CLASS="quote">Um, Autometer does. Mine goes 0-30in/Hg - 0-20psi. Look on their website.</TD></TR></TABLE>
yup that is what i am running
Old Feb 8, 2004 | 07:26 PM
b18c1wes's Avatar
im only running 5-7psi i want to see the damn thing move i want a 0-20psi with a -10vac full sweep would be nice. does anyone make a boost gauge for low boost app. doesnt make sense not many people are in the 20psi range or the 15 for that matter.im going to have to put the gauge up against my eye... i dont need to see while i drive
Old Feb 9, 2004 | 05:50 AM
MADEINIRAQ's Avatar
i don't see the need for a guage that reads less than 20psi.
if you are running 5-7psi. then the 20 psi is perfect. you want to be in the middle of the range.. 0-20... 7 is pretty close
if you boost spike.. it will be very clear on the guage.
the 20psi guage makes you realize that you aren't running enough boost
Old Feb 9, 2004 | 06:45 AM
vtec.dc2's Avatar
having a boost gauge that reads up to 15psi is like having a speedometer that stops at 80mph. if you want better readings, invest in a larger diameter gauge, you could also get peak-n-hold gauge, or electronic boost controllers record peak-n-hold.. you won't always be able to keep an eye on boost gauge, but with peak-n-hold, you won't skip anything.
Old Feb 10, 2004 | 08:03 PM
b18c1wes's Avatar
i have a 0-35psi boost gauge now with no vacuum so you can imagine why i want one smaller... 0-20 psi is very reasonable but i want one with no vac because it takes up most of the gauge -30vac-0-20psi instead of just 0-20psi.. i can barely ready the one i have now its ok but i want more accurate one (by accurate i mean me being able to see whats going on)
Capt. Jimbo McSubipants
Jul 7, 2005 05:25 PM
duh blacksheep
Aug 3, 2004 01:42 PM
Street Ghost
Jul 5, 2004 07:35 PM
Muglit
Apr 4, 2002 01:15 PM
Defiant1999
Jan 5, 2002 07:10 AM
