measuring compressor inducer wheel?
Yessir...Make sure to take accurate measurements of the top and bottom of the compressor wheel. There is a formula floating around HT somewhere that tells you how to calculate the exact AR from those 2 measurements
You can find alot of good information also on the following link.
http://www.turbobygarrett.com/turbob...o_tech102.html
yea carefully tapping around the perimeter on the housing where it seals to the chra till it comes loose with a rubber mallet is probably your best bet if its not coming off by hand.
One thing to be careful of, is that some turbos have a little rubber O-ring around the perimeter of the backplate. What this basically means is when you take the housing off, be careful not to twist it back and forth a lot or you risk tearing that O-ring
Stock@$$GSR
Apr 18, 2002 06:22 AM
