MBC question
Old Mar 5, 2004 | 03:42 PM
B18Flip's Avatar
Default MBC question
Just bought one of those ebay mbc's and one of the barbs has a hole or vent in it (the top one in the pic) ......is it supposed to have that? I always thought it was supposed to be a closed system
Old Mar 5, 2004 | 04:08 PM
mildly.interesting's Avatar
Default Re: MBC question (B18Flip)
its not really a vent, just a marker....quit worrying and put it on...
Old Mar 5, 2004 | 04:10 PM
m R g S r's Avatar
Default Re: MBC question (mildly interesting)
If it is a hole, I don't think that it will control the boos at all.
Old Mar 5, 2004 | 04:13 PM
B18Flip's Avatar
Default Re: MBC question (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">If it is a hole, I don't think that it will control the boos at all. </TD></TR></TABLE>
yeah thats what i was thinking, i dont think its just a marker since it goes all the way through and air comes out of it. Should i plug it up?
Old Mar 5, 2004 | 04:23 PM
turbo_ef9's Avatar
mine had a hole too and they said it was to bleed out a lil bit of air or some ****.. it'll still work..
Old Mar 5, 2004 | 04:30 PM
B18Flip's Avatar
Default Re: MBC question (eli_vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang &raquo;</TD></TR><TR><TD CLASS="quote">mine had a hole too and they said it was to bleed out a lil bit of air or some ****.. it'll still work..</TD></TR></TABLE>
cool, good to hear
Old Mar 5, 2004 | 04:36 PM
shadow103rd's Avatar
It kinda looks like a release valve......in case that nipple sees to much boost the seal will blow and consequently make it so that the boost controller doesnt work and boost cant build up......basically making it always open....just my opinion....kind of a safety feature i think...
Old Mar 5, 2004 | 05:26 PM
Cramerox's Avatar
hmm depending on what kind it is, it might still work. Like if it had a ball bearing inside. kinda sketchy tho....i personally wouldnt risk it.
Old Mar 5, 2004 | 05:32 PM
B18Flip's Avatar
Default Re: MBC question (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">hmm depending on what kind it is, it might still work. Like if it had a ball bearing inside. kinda sketchy tho....i personally wouldnt risk it.</TD></TR></TABLE>
yeah its the ball and spring type, they're visible from looking in the barbs....i'll try covering up the hole and leaving it open and see what works better
Old Mar 5, 2004 | 05:54 PM
rjardy's Avatar
the hole is supposed to be there, its the same design as the hallman MBC, it works fine, leave the hole, but make sure that you install it with that hole up just like your holding it in the pic.
Rob
Old Mar 5, 2004 | 06:10 PM
project dc2's Avatar
Default Re: MBC question (rjardy)
bleed hole is supposed to be there,. without it itll creep.
Old Mar 5, 2004 | 06:16 PM
coolme's Avatar
the hole is supposed to be there so your wastegate doesn't stay open, if you blow into a tube then hold both ends closed you have tube pressurized tube and will stay till you release an end, the hole is just a release its supposed to be there, don't worry about it
Old Mar 5, 2004 | 06:41 PM
integrx's Avatar
New User
http://www.sportcompactcarweb....rol08/
"Once the spring is overcome by boost pressure, most of the air makes its way to the actuator, while a bit is allowed to bleed off to atmosphere. This bleed is necessary, as once you're back out of boost"
Old Mar 5, 2004 | 07:50 PM
turbo_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">
cool, good to hear </TD></TR></TABLE>
yea be a lil bitch about it.. i hope your **** blows up :
Old Mar 5, 2004 | 07:55 PM
B18Flip's Avatar
yea be a lil bitch about it.. i hope your **** blows up : </TD></TR></TABLE>
WTF?? it was a valid question *** hole
Old Mar 5, 2004 | 07:58 PM
turbo_ef9's Avatar
uh huh.. that mbc is pretty clean though...
jthegod
Sep 20, 2007 10:18 AM
RaceKarWilly
Feb 3, 2005 01:20 PM
redboost10
Jan 14, 2004 07:03 PM
BrockGrimes
13
Jan 6, 2004 12:34 PM
Attoir
Dec 18, 2003 03:05 PM
