maxrev manifold Version 2.0 (prototype pics) & differences between tubing ...
Old Apr 15, 2002 | 10:20 PM
Full-Race Geoff's Avatar
Default maxrev manifold Version 2.0 (prototype pics) & differences between tubing ...
Here is the first pic. This shows the difference between SS tubing (16 gauge) and the forged stainless tubing that we (Maxrev) use on our manifolds. The 16 guage tubing has a wall thickness of 37.5 thousandths (0.0375") and the 8 gauge tubing has a wall thickness of 168 thousandths (0.168").
the second picture is the picture of the prototype semi-equal length manifold. I didnt get a chance to finish it tonite, but i should be able to finish it wednesday. Use your imagination to fill in the last runner. The wastegate will intercept the collector in the front. More pictures to come soon. This manifold will not allow you to retain AC.
Old Apr 15, 2002 | 10:33 PM
falcongsr's Avatar
What is this crap?
Default Re: maxrev manifold Version 2.0 (prototype pics) & differences between tubing ... (FFgeoff)
nice manifold!
let me guess...the forged stainless tends to hold up better than the .0375" stuff?
Old Apr 15, 2002 | 10:37 PM
Rob03Pro5's Avatar
Can you post a pick of the collector chamber? I'm hoping you will put a divider plate to block the gases from cyl 1 and 4 from each other. This looks like the "Turboimports" manifold.. http://www.a1jdmengines.com/home.htm
Old Apr 15, 2002 | 11:07 PM
Default Re: maxrev manifold Version 2.0 (Rob91TSi)
the collector pics will be posted when its all finished. Its a pretty functional collector. The tubes from cyl 1 and 4 are both firing downwards, even tho that pic doesnt show it too well. Ill get more pics up shortly.
Old Apr 15, 2002 | 11:16 PM
int3gra's Avatar
Default Re: maxrev manifold Version 2.0 (FFgeoff)
how much will it be going for (estimate)
Old Apr 16, 2002 | 12:57 AM
PROFILES2000's Avatar
Default Re: maxrev manifold Version 2.0 (int3gra)
how bout u let me prototype one for you. im from NJ so pick up would be easy
Old Apr 16, 2002 | 01:10 AM
Kamin's Avatar
Default Re: maxrev manifold Version 2.0 (PROFILEGSR)
Very nice.
too bad you cant retain AC...
Old Apr 16, 2002 | 01:12 AM
Default Re: maxrev manifold Version 2.0 (KAMiN)
who needs AC? i only used mine liek 2 times and one of the 2 times was to see if it still worked now mine is out of the car completely
Old Apr 16, 2002 | 02:44 AM
BodyKits NW's Avatar
Come on lol the guys needs AC, he lives in Arizona lol
Old Apr 16, 2002 | 03:56 AM
BlueSi2k's Avatar
will this manifold be prone to cracking like other tubular manifolds or do you think it should be as reliable as a log style? thanks
Old Apr 16, 2002 | 05:21 AM
blowncivichb's Avatar
Default Re: maxrev manifold Version 2.0 (BlueSi2k)
Yep...gotta have A/C here too. It's a must-have.
Ever been to STL in the summer? A/C
Tom
Old Apr 16, 2002 | 05:34 AM
int3gra's Avatar
Default Re: maxrev manifold Version 2.0 (blowncivichb)
just drive in your boxers dammit!!
u cant have luxury AND speed.......and get rid of the passenger also, they are giving off excess body heat.
Old Apr 16, 2002 | 06:09 AM
abraunb16's Avatar
New User
I'd be happy to test that mani for you. I have the older log style mani for the B series. I'm in AZ also. Later Allen
Old Apr 16, 2002 | 06:36 AM
12 oz.'s Avatar
Geoff,
Looks good as usual, I sent you an email about the kit and a couple of Qs get back to me when you can.
Old Apr 16, 2002 | 06:40 AM
falcongsr's Avatar
What is this crap?
Default Re: maxrev manifold Version 2.0 (abraunb16)
how are you liking your 'old' style log manifold?
Old Apr 16, 2002 | 07:25 AM
ArizonaTurbo's Avatar
So what are these tubular stainless steel manifolds going to run in price?
Old Apr 16, 2002 | 07:28 AM
abraunb16's Avatar
New User
Default Re: maxrev manifold Version 2.0 (falconGSR)
falconGSR, I have yet to really try out the manifold. My car starts it just won't idle or hold any type of rpm. So I really haven't had a chance to see what it can do in my car. My friend Victor/B18-Bomber used the same manifold on his GSR and recomended it to me. He made good power with it and for the price I paid it was a no brainer.
Old Apr 16, 2002 | 08:50 AM
BlueSi2k's Avatar
ttt so will this be as reliable as a log style or will it be prone to crack eventually?
thanks
Old Apr 16, 2002 | 09:02 AM
It will be *almost* as strong as a log style manifold. The only strength difference is becuase the turbo hang out farther (more leverage to crack welds) A log style is inherently strong as it is one tube, and a tube is the strongest shape to both torsional stresses and strains. The fact that we use the 8 gauge forged material rather than tubing should make it live much longer than most competitors.
I once had a conversation with a manifold builder who said "Build it out of whatever you want, it will eventually crack; There is no miracle metal... well none that anyone can afford"
As far as i know, this is the strongest material utilized in a manifold for a reasoanbly priced manifold (an inconel manifold would probably run about 2500). This Stainless steel is very difficult to work with and cut, but its durability more than makes up for it. A customer with a heavily abused '00 Si (notorious for bad motor mounts) had completely torn up motor mounts. He had a maxrev kit on the car and actually ended up cracking the turbo housing before cracking the manifold. While this is not at all a good thing, it made me happy.
To be quite honest im not sure how much of a performance difference the longer runners and downward pointing collector will make. This will be on the dyno in about 4 weeks, so ill find out, and report the findings (ive wondered for a long time if longer runners make power...) We have seen some cars put out very good numbers with the log style -- similar to ones put out by more exotic manifolds.
Old Apr 16, 2002 | 10:40 AM
Giuseppe's Avatar
looks good
[Modified by Giuseppe, 8:02 PM 4/16/2002]
Old Apr 16, 2002 | 05:54 PM
Prelussion's Avatar
Default Re: maxrev manifold Version 2.0 (Giuseppe)
TTT
Old Apr 16, 2002 | 06:31 PM
paulzy's Avatar
Default Re: maxrev manifold Version 2.0 (Prelussion)
I'm still waitin gto see what the full euqal lentgh looks and works like....when' s the date for releasing the e.l. mannys?
Old Apr 16, 2002 | 07:05 PM
88CRXHybrid's Avatar
i am looking forward to seeing dyno data on this manifold
Old Apr 16, 2002 | 07:25 PM
HXMan's Avatar
Default Re: maxrev manifold Version 2.0 (88CRXHybrid)
Are you going to produce a 3" DP to go along with this manifold?
Old Apr 16, 2002 | 07:39 PM
Default Re: maxrev manifold Version 2.0 (Mad HXMan)
No price/release date yet, and the downpipes will only be 3".
