maxrev manifold+ac
Old Mar 26, 2002 | 06:58 PM
01geeser's Avatar
New User
Default maxrev manifold+ac
has anyone been able to successfully run the maxrev manifold with a/c in an integra? losing a/c is not an option for me. so im going to have to mount the a/c fan on the front. heres the question, should i try to mount the fan between the a/c condenser and the radiator? or can i mount it in front of the condenser. would there be any difference?
edit:just noticed that i cant mount it between the condenser and radiator. would the fan be effective in front of the condenser?
[Modified by 01geeser, 6:43 AM 3/27/2002]
Old Mar 26, 2002 | 09:50 PM
dustin's Avatar
Default Re: maxrev manifold+ac (01geeser)
The thing is that the the condenser fan must mount with the flush side against the radiator/condenser, and putting the fan in front will reverse the air flow direction. You'd need to reverse polarity and reverse the fan blades themselves (which you can't do with the stock fans).
Get one aftermarket 12" slim line fan (I think mine are made by perma-cool) and mount it in front of the condenser. It will work fine then.
Dustin
Old Mar 26, 2002 | 10:03 PM
01geeser's Avatar
New User
Default Re: maxrev manifold+ac (dustin)
yeah thats what i was thinking of doing. whats the purpose of that fan anyways, to cool down the condenser or the radiator? if its for the radiator then wouldnt having the fan in front of the condenser be a restriction?
BTW whats the thickness on those 12" fans that you are using right now?
Old Mar 26, 2002 | 10:32 PM
dustin's Avatar
Condenser fan is for the condenser It only turns on when the A/C is on.
I'm not sure on the thickness... they are thinner than both my FAL fans and stock fans...
Old Mar 26, 2002 | 10:47 PM
01geeser's Avatar
New User
so even without that fan there i should be able to drive my car just as long as i dont use a/c right?
guess im gonna be shopping for fans then.
[Modified by 01geeser, 7:47 AM 3/27/2002]
Old Mar 27, 2002 | 09:17 AM
Full-Race Geoff's Avatar
The idea is basically this:
Using A/C makes your car run hotter. As a result, the second fan is put in to increase airflow across the radiator, so the car will not run hot in extreme circumstances.
Many cars that have a/c systems, run fine without the second fan. I would reocmmend taking the fan out completely first and more than likely you will not have any overheatiing issues. If it runs hotter than you would like, then worry about a slim fan, or swapping the fan to the other side.
Old Mar 27, 2002 | 10:08 AM
racerxadam's Avatar
Default Re: maxrev manifold+ac (FFgeoff)
the second fan is there to help the condesor radiate heat by introducing a high volume of fresh air to the cooling fins. not to help cool the engine because it runs hotter with the a/c on. without the second fan the a/c would be very ineffiecient and may not work at all. if it does work the high side pressure in the a/c system will be way over what it should be. if you ever get a chance hook up some gauges to your ac system and turn it on. the high side should be somewhere near 250 psi. then to view the effects of the second fan you could either unplug it or spray water on the condensor(simulating the added cooling effect of driving.
cliff notes: if you want to keep a/c, figure out how to rig up the second fan
Old Mar 27, 2002 | 12:45 PM
Cramerox's Avatar
Default Re: maxrev manifold+ac (racerxadam)
any pictures of these front mount fans? how are they mounted, zip ties? i Got the same problem with the maxrev kit......i thought it was suppose to clear the AC fan.
Old Mar 27, 2002 | 12:47 PM
racerxadam's Avatar
Default Re: maxrev manifold+ac (Cramerox)
i'll be taking pics tonight.
Old Mar 27, 2002 | 12:50 PM
BLKCRX's Avatar
does this problem effect del sol's ? (crx's)
or just on tegs
Old Mar 27, 2002 | 12:55 PM
01geeser's Avatar
New User
Default Re: maxrev manifold+ac (BLKCRX)
thanks for that clarification geoff. so basically, you need more cooling power when running a/c.
Old Mar 27, 2002 | 10:18 PM
ion_four's Avatar
I've got a 93 Civic EX Coupe and I'm wondering the same thing about keeping the AC...does anyone know of a manifold/downpipe that won't get in the way of the condenser?
Nisif
12
Apr 29, 2009 11:39 AM
H2290
Sep 7, 2007 09:31 PM
zexifiedlude
May 16, 2006 01:22 PM
go2sleep
Jan 26, 2006 11:19 AM
95gsr
May 29, 2002 03:32 PM
