maxrev downpipe
Old Jan 9, 2003 | 12:12 PM
lsvtec101's Avatar
Default maxrev downpipe
i was looking at a maxrev downpipe and it had a circular 4 bolt flange, but the kit comes w/ a t3/t4 that has the 5 bolt flange... so will the maxrev downpipe fit this t3t4?
Old Jan 9, 2003 | 12:15 PM
bgod's Avatar
Default Re: maxrev downpipe (aemcivic_02917)
no it won't
you either need a 5bolt flange for your downpipe or a turbine housing with a 4 bolt flange.
Old Jan 9, 2003 | 12:18 PM
lsvtec101's Avatar
Default Re: maxrev downpipe (bgod)
can you buy a maxrev downpipe w/ a 5 bolt flange ?
Old Jan 9, 2003 | 12:33 PM
BROOD's Avatar
Not that I am awhere of.........
Where did you buy this kit from? Did the turbo and downpipe come from the same place?
You will probably have to have a five bolt flange welded to the maxrev DP after removing the four bolt flange.
*edit: I see the manifold/DP were bought independently of the turbocharger, that was the issue*
Best bet would be to mount the manifold and turbo up so you can mock up the correct 5 bolt flange position before welding it up.
[Modified by SLPR, 2:20 PM 1/9/2003]
Old Jan 9, 2003 | 12:36 PM
bgod's Avatar
Default Re: maxrev downpipe (SLPR)
just send it back to maxrev. they'd probably be more willing to give you a new downpipe flange then a turbine housing.
if you got the kit used, then you can buy a 5bolt flange and have a muffler shop weld it on. not sure who would sell the flange, but i'm sure most turbo retailers.
Old Jan 9, 2003 | 12:55 PM
lsvtec101's Avatar
that sucks, i just bought the maxrev manifold , and wanted to get the downpipe so it would bolt right up... wonder if maxrev would put a 5 bolt flange on..
Old Jan 9, 2003 | 01:21 PM
johnisenglish's Avatar
That's exactly what I'm doing w/ my MaxRev DP. http://www.cheapturbo.com and http://www.roadraceengineering.com/ sell the flanges, I believe. So does Turbonetics
Old Jan 9, 2003 | 02:07 PM
lilxvtecxpwr's Avatar
Default Re: maxrev downpipe (johnisenglish)
just buy a 5 bolt flange and take it to a muffler shop. tell them to cut off the 4 bolt flange and weld on the 5 bolt flange. pretty simple task.
by the way, here is my maxrev downpipe...bling bling action
Old Jan 9, 2003 | 03:31 PM
BoostedH23a1's Avatar
Default Re: maxrev downpipe (lilxvtecxpwr)
yea i think maxrev just flanges for garrets not turbonetics..
Old Jan 9, 2003 | 03:59 PM
Canuk_SiR's Avatar
holy bling! Mine's staying nice & dirty, she gets no love from me
Old Jan 9, 2003 | 04:33 PM
pub's Avatar
pub
Default Re: maxrev downpipe (Canuk_SiR)
I bought my 4-bolt flange from CheapTurbo.com. Should arrive sometime soon.
Shoulda waited for this guy to cut his off.
Old Jan 10, 2003 | 03:22 AM
lsvtec101's Avatar
Default Re: maxrev downpipe (BoostedH23a1)
i think maxrev does turbonetics cause mine is a garett
Old Jan 15, 2003 | 08:37 AM
dustineck's Avatar
Maxrev uses garret turbos. By the way, is you down pipe chromed or polished?
Old Jan 15, 2003 | 08:56 AM
KC GSR's Avatar
Default Re: maxrev downpipe (AzSiRacer)
that downpipe is badass
Old Jan 15, 2003 | 02:56 PM
civbeater90's Avatar
Default Re: maxrev downpipe (KC GSR)
hey guys how thick is the maxreva and does it clear ac on a d?
Old Jan 16, 2003 | 05:31 PM
Default Re: maxrev downpipe (civbeater90)
bizzump
Old Jan 16, 2003 | 05:46 PM
Cramerox's Avatar
1.Its pretty thick SS very nice stuff
2. yes it clear the AC 2.5 inch diameter
Old Jan 16, 2003 | 06:13 PM
Default Re: maxrev downpipe (Cramerox)
so its 2.5 all the way?
Old Jan 16, 2003 | 06:25 PM
Cramerox's Avatar
99.99 percent sure
Old Jan 22, 2003 | 08:49 AM
ricodemus's Avatar
Another related, but off topic Q : Are any downpipes interchangeable? If I have a Drag, but I want one with a flexpipe, could I use any of the other downpipes for bseries kits?
Old Jan 22, 2003 | 08:56 AM
TurbothisLS's Avatar
easiest thing to do would be to cut the flange off and weld a new 5 bolt flange to it.
muffler shops don't charge that much to do that and you can get the 5 bolt flange from almost anywhere.
cheapturbo.com for one
or majesticturbo
TeamShiftPoint
Dec 16, 2004 11:11 AM
masterasia
Jun 27, 2004 09:49 PM
Acura_I-RS
Jul 31, 2003 02:43 PM
tegasaurus
Mar 29, 2003 05:18 PM
