Max safe boost on b20vtec..search kind of....
Old Aug 20, 2005 | 09:46 PM
1990hondaHF's Avatar
Default Max safe boost on b20vtec..search kind of....
"The search server is temporarily unavailable. Please try again later."
oh well, if tuned properly, what is the max recomended boost for the b20vtec combo using an unsleaved stock bottom end?
Old Aug 21, 2005 | 04:56 AM
twisted civic's Avatar
Default Re: Max safe boost on b20vtec..search kind of.... (1990hondaHF)
0 psi, b20's weak.
Old Aug 21, 2005 | 05:38 AM
B20T CRX's Avatar
Default Re: Max safe boost on b20vtec..search kind of.... (twisted civic)
we have run as much as 13psi on stock be B20's. 8-10psi pump gas and 11-13psi race. your turbo set-up will play a big part too.
Old Aug 21, 2005 | 09:08 AM
DD93eg's Avatar
Default Re: Max safe boost on b20vtec..search kind of.... (B20T CRX)
10.8psi with T3 super 60 made 275whp and 210 torque. St00pid tuned
Old Aug 21, 2005 | 09:32 AM
Default Re: Max safe boost on b20vtec..search kind of.... (DD93eg)
I'm glad to hear that b20's can take some boost. I was no where looking to go 10+ PSI, 5-7 was more my range. I'm not a racer, I just want to add a little umph to my project. I hope I could get a few more posts on how much boost you b20vtec guys are running....
Old Aug 21, 2005 | 01:37 PM
beerbongskickass's Avatar
Why go turbo if you just want a little umph? Sounds like a waste of money and time to me. B20's can't handle a decent amount of power for very long, the sleeves will crack. I guess if your only boosting a few pounds you can get away with it for a while. I would just pick up any other b-series block and boost that... it will be much safer and more upgradeable.
Old Aug 21, 2005 | 01:39 PM
urbansi's Avatar
many people like to say that the b20's dont like boost, if properly tuned on a healty motor it should be able to take up to 10psi hp is a different story. with many motors that honda made its unfortunate that nothing was ever put out with a forged bottom end i would say that you need to see what shape the motor is in before boosting and then decide what hp levels that you are looking for, not boost levels. hope to help, i think that issues on boost and b20's is a pretty covered issue so look around and see what else people have done with the stock block and boost
JDM_Acccord
Jul 5, 2007 03:24 AM
justinb
Jun 25, 2005 04:40 PM
projectTeG
Nov 7, 2003 06:56 PM
X2BOARD
Jun 18, 2003 10:14 AM
infamousALLMTR
Jun 28, 2002 10:17 AM
