max rev manifold owners
Old Dec 16, 2001 | 05:01 PM
D-SPEED's Avatar
Default max rev manifold owners
who has "de-burred" excess metal from the inside of the runners ? I found a few little scraps still hangin on the inside, and i just didnt want them to go through the turbine. If so, what did you use to clean it up ?
Old Dec 16, 2001 | 05:29 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: max rev manifold owners (D-SPEED)
I don't know if this would work, get a thing of compressed air, blow it on outta there.
Old Dec 16, 2001 | 05:52 PM
brian b's Avatar
New User
Default Re: max rev manifold owners (ForcedAccord)
i had to use a steel wheel and a carbide sander on a dremmel on quite a few surfaces on the inside of this manifold.. its a well made piece, just missing a couple minor details.. but thats part of why its so inexpensive
Old Dec 16, 2001 | 06:28 PM
D-SPEED's Avatar
Default Re: max rev manifold owners (brian b)
cool i think i will find a dremel to use.
on your guy's WG flange, was it sanded down right near the actual exhaust outlet ? On mine, it looks like they ground it down to make a flat surface, but now the middle of the flange surface sits a tiny bit lower than around the mounting bolts, ...i was afraid this would cause a bad seal between the flange and and WG because the middle section of the gasket wont be recieving the same amount of pressure on it.
gehlSRT
Welding / Fabrication
Oct 11, 2011 09:34 AM
pcguy760
Aug 13, 2008 06:04 AM
bunnyrabbit
Sep 14, 2005 09:39 AM
RACEPAK
May 1, 2005 03:06 PM
lilxvtecxpwr
Feb 8, 2003 10:02 AM
