max psi on stock head??
Old Jun 12, 2003 | 11:58 AM
spacetuna's Avatar
Default max psi on stock head??
What's the max PSI you can run on a stock head????
Old Jun 12, 2003 | 12:17 PM
b18cTurbo's Avatar
Default Re: max psi on stock head?? (spacetuna)
its not psi but hp max your looking for!
Old Jun 12, 2003 | 12:35 PM
spacetuna's Avatar
Default Re: max psi on stock head?? (sleeper007)
Ok, what's max HP??
My new setup will include
1991 Integra LS
B16a
rods
pistons
blockguard
450 injectors
fuel rail
fuel pump
T3/T4B
SRP headstuds
Hondata
Wanting to run around 15psi and want to know if I need valves/valvesprings
Old Jun 12, 2003 | 02:00 PM
MNturbosi's Avatar
I'm also interested in this topic. Is anybody out there running high boost successfully on a built block with a stock head?
Old Jun 12, 2003 | 02:44 PM
crxjake's Avatar
talk to st00pid he runs 20lbs on a stock motor
Old Jun 12, 2003 | 03:08 PM
gitwidit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spacetuna &raquo;</TD></TR><TR><TD CLASS="quote"> Wanting to run around 15psi and want to know if I need valves/valvesprings</TD></TR></TABLE>
Valve springs and retainers will let you spin your engine higher w/o getting into valve float. As far as valves are concerned, you can get oversized, you can get valves that are more tolerant to heat, many options. At 15psi I don't think you'll need any work there. BTW, do you have an intercooler? Didn't see it in your setup.
Old Jun 12, 2003 | 04:24 PM
shermanyang's Avatar
Default Re: max psi on stock head?? (GITWIDIT)
soon i will be running 13-15 psi on my built block/stock head. if i can get the 3bar map to work with uberteg's chip i'm gonna do it this weekend...and of course get it dyno tuned.
Old Jun 12, 2003 | 05:26 PM
turbotypeR@SPEC's Avatar
25 Year Member
i run mine at 27psi and 9000 rpm.the only reason i have not gone above 27psi is that the boost controller won't turn it any higher for some reason.
Old Jun 13, 2003 | 06:14 AM
spacetuna's Avatar
Default Re: max psi on stock head?? (turbotypeR)
27 psi!!! wow. Well, I won't waste my money on the valvetrain till later I guess. Could you tell me more about ubertegs chip??? Do you need a vafc to tune it or how is it controlled?
Old Jun 13, 2003 | 06:35 AM
B18c1turboedEK's Avatar
My friend is running 25psi on a stock head.. alot of people say that honda heads can handle what u throw at them.. You wanna upgrade valves and so forth when u wanna start reving higher i belive.. DONT SHOOT ME IF IM WRONG.
Old Jun 13, 2003 | 09:23 AM
spacetuna's Avatar
Default Re: max psi on stock head?? (Koticcivic4u)
I won't shoot you, I'll just beat you with my snapped rod.
T3k C
Jun 14, 2007 09:37 AM
mrx
Dec 11, 2005 08:22 AM
Hoodwinked
Jan 15, 2004 09:52 PM
Markaccord95
Jan 28, 2002 10:43 AM
