Map Signal pin location?
Old Aug 4, 2003 | 08:48 AM
spooned out's Avatar
Default Map Signal pin location?
I did some search and came up with slot D17 for Map signal, now my question is on the site i found the location is D17 but wire color pink/white instead of solid white. Now there is a solid white wire but its not in this location can anyone shed some light on this? car is 95Si stock ecu wiring with P30ecu unelss map signal location is different from the P28
Anyone with a greddy kit on a 92-95 civic using the "blue box" could you tell me what location and wire color did you cut for the Map signal.
Old Aug 4, 2003 | 06:39 PM
Joseph Davis's Avatar
Default Re: Map Signal pin location? (spooned out)
I've seen no less than three different MAP wire colors that I can think of... white, pink, and lt blue. The notes in front of me say pink/white.
D17 is the correct pin.
Old Aug 5, 2003 | 05:27 AM
EE_Chris's Avatar
Default Re: Map Signal pin location? (J. Davis)
I agree that D17 is the MAP input. My Q is this: Not having a 5th gen Helms, I surfed over to Chiltons Repair Library where they have assorted engine wiring schematic. This is for 92-95 except the VX model: Schematic Diagram
In it, you'll notice that the "D" connector isn't even used. Would anyone hazard a guess as to which engine this is for?
***CAUTION to those that troubleshoot without a Helms.***
Old Aug 5, 2003 | 08:32 AM
Yeah the Pink/white wire is in the slot D17 pin so thats the one i cutt for the map signal, just wanted to be sure....
HatchMo
Oct 12, 2008 04:46 AM
flip1199
Dec 28, 2003 11:12 PM
spooned out
Aug 5, 2003 09:37 AM
xXx Justin xXx
Jun 18, 2003 09:49 AM
