Map sensor vac source?
Old Jan 23, 2005 | 05:19 PM
siblues's Avatar
Default Map sensor vac source?
I just wanted to ask your opinions on what would be the best place to get the vac source for my map sensor ? I have a map blockoff plate that I can tap and install a barb fitting for the vac source in the oem location and I am currently running a skunk2 im which has a extra spot for a type r sensor that my b16 doesnt have so I seales it up when I installed it. The sensor location is on the third runner I believe and just wanted to know which spot would be better?
Old Jan 23, 2005 | 06:04 PM
mrbsponge's Avatar
why do you have a MAP sensor block off plate on???
why would you not just connect it where it is supposed to go, or are you talking about a GM 3 BAR map
Old Jan 24, 2005 | 02:00 PM
siblues's Avatar
Default Re: (mrbsponge)
I am planning on using the aem 5 bar and I am just wondering if the oem location would be the best spot for the vac source or is it ok on the intake manifold?
Old Jan 24, 2005 | 02:01 PM
11psiTurboSI's Avatar
Default Re: (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I am planning on using the aem 5 bar and I am just wondering if the oem location would be the best spot for the vac source or is it ok on the intake manifold?</TD></TR></TABLE>
intake manifold is fine
Old Jan 24, 2005 | 02:02 PM
RyanEJ8's Avatar
Intake manifold is fine. I have my GM 3bar hooked up to my vacuum manifold which is run off of a 3/8" nipple on the intake manifold.
ekk41
Oct 24, 2007 05:16 AM
hovic
Sep 28, 2004 01:25 PM
BoostedJeff
Sep 24, 2004 09:27 AM
CiViC SiR
Oct 20, 2003 11:00 AM
Nextelbuddy
Jul 27, 2003 08:27 PM
