MAP Sensor question! Is it possible?!
Can i read my A/F's off my motorola 2.5 map sensor?
someone told me somthing like that, trying to find out if possible.
I have the greddy e-01 boost controler an it says for the air/fuel function to tap into the MAP sensor....
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riddlinkid1986 »</TD></TR><TR><TD CLASS="quote">can a stock 02 sensor be set up like a wide band sensor? differences?</TD></TR></TABLE>
no the stock o2 sensor is a NARROW band. o2 sensor's work by reading voltages the stock o2 sensor does not read as wide of a range.
a wideband sensor reads voltage from 1-5 volts a narrow band does not.
D15JDMARIO
Mar 3, 2007 07:39 PM
Hoodwinked
Dec 1, 2003 12:13 PM
