Map sensor?
Old Dec 12, 2012 | 12:05 PM
PARADOX_sf's Avatar
Icon2 Map sensor?
Hello.
I am searching for good, stable and high precision 3,5 bar or 4bar map sensor. What would you advice me?
Thank you!
Old Dec 12, 2012 | 12:18 PM
carlos8's Avatar
Default Re: Map sensor?
there's a few good thath i used , Omni,hondata,Xenocron.
Right now i use a 4bar omni for two years with out a problem.
Old Dec 12, 2012 | 12:59 PM
Steeve_Civic's Avatar
4b Omni is correct and price around $90 - $100
I'm using it right now too
Old Dec 12, 2012 | 03:47 PM
wantboost's Avatar
Who is Mr Robot?
What engine management are you using? I use an aem 3.5 bar but I have a standalone.. not sure if it will work with OEM based management
Old Dec 13, 2012 | 01:32 PM
TheShodan's Avatar
Moderator
Hondata, AEM EMS , and Ominipower all have 3.5 and 4 bar MAP sensors that replace the stock OEM sensor in the same location. There's really not one better than the other as they all use similar internal components to give the same signal. So in either case, as long as you don't try an eBay knock-off, you can't go wrong.
Old Dec 13, 2012 | 02:25 PM
SiRCiviC94's Avatar
Do they require more tuning compared to stock other than programming in which sensor is used?
Old Dec 13, 2012 | 02:31 PM
TheShodan's Avatar
Moderator
There needs to be adjustments made, yes, as each map sensor displays different voltage that the ECU system sees based upon what BAR the sensor is good for.
For example. If you use a 2.5BAR sensor and your system is calibrated as though its expecting a 3bar sensor, the signal will be off and the computer would think you're utilizing say 12 psi of boost pressure, when its really 8. So it is important to calibrate the map sensor properly to your engine management system.
Old Dec 16, 2012 | 10:31 AM
danny_6725's Avatar
I would go wit a hondata map sensor
Old Dec 16, 2012 | 02:10 PM
TheShodan's Avatar
Moderator
And your reasoning?.............
These one sentence answers never did make any sense. Hell, you didn't even quote anyone.
Old Dec 17, 2012 | 01:27 AM
Psychoteen101's Avatar
Im running an AEM 3.5 bar. Havent had an issue. I dont have a standalone, im running Kpro/Kmanager and they give the option to select an AEM map. Also gives a bunch of other options as well as a custom one if not listed, which im sure takes more tweaking to work. Im assuming s300 has the same feature. Not sure what the capabilities are with chrome, neptune, or other softwares that are similar.
Old Dec 17, 2012 | 03:27 AM
yungkhmer's Avatar
I run a SPEEDFACTORY 4bar, their local to me and no problems at all with it.
Old Dec 17, 2012 | 04:15 AM
LightningTeg's Avatar
Community Builder
I have an AEM 5 bar mounted to the firewall. On hot days it will occasionally go wack, (especially at the track for some reason) and stop reading, requiring me to unplug the sensor and unplug battery and reset the system. Its weird and I cannot place the blame on the MAP sensor completely because I really dont know, but its wired fine and the ecu is ok, but I never had the issue with my Omnipower.
Doodasi
Nov 1, 2017 02:54 PM
88YellowRexSi
Nov 30, 2005 10:35 AM
vtekthis
Apr 10, 2005 06:00 AM
int3gra
Jul 4, 2003 11:49 AM
R THIS
Jun 27, 2003 09:41 AM
