Map Sensor
Old Nov 20, 2007 | 06:46 PM
nihad's Avatar
Default Map Sensor
What map sensor should i use for boost at 15psi. And which do u guys recommend
Old Nov 20, 2007 | 06:48 PM
nowtype's Avatar
Default Re: Map Sensor (nihad)
Motorola 2.5bar, GM 3 bar, Motorola 3bar, AEM/Klavico 3.5bar, Motorola 4bar, AEM/Klavico 5bar, Motorola 5 bar.
Old Nov 20, 2007 | 06:49 PM
T9U4ReBgO's Avatar
im goin to use a gm 3 bar...thats what everyone recommended for me bc i think the stock map sensor is good for 11.5 psi...correct me if im wrong...
Old Nov 20, 2007 | 07:08 PM
nihad's Avatar
Default Re: Map Sensor (nowtype)
I have heard that the motorola aren't as good as the gm. Just want to know which one would be the best for the price and i want a good product to work the right way.
Old Nov 20, 2007 | 07:41 PM
Schister66's Avatar
Man U FTW
Just get the GM 3bar...it may be a little more expensive than the others, but it has been used successfully on many setups. Also, it reads to 29psi so chances are, you'll never have to get a different one.
Old Nov 20, 2007 | 07:56 PM
JDMeg95's Avatar
Default Re: (Schister66)
gm 3 bar
Old Nov 20, 2007 | 09:05 PM
nowtype's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that the motorola aren't as good as the gm. Just want to know which one would be the best for the price and i want a good product to work the right way.</TD></TR></TABLE>
Negatory. Motorola sensors are significantly better. They are just more fragile.
Old Nov 30, 2007 | 04:54 PM
nihad's Avatar
what car does the 3bar gm map come off of. The one at the dealers dont have the # on it so i dont know if it 2bar or 3bar i have a 886# which is a 2bar i guess.
Old Nov 30, 2007 | 05:34 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (nihad)
what management you using?
i would just go with the 3 bar. as most if not all systems support it, i dont know if the s200 supports anything other than a stock or 3 bar thats why i asked. i dont think the 200 supports the 2.5.
but yeah you will probably grow into it.
Old Nov 30, 2007 | 05:47 PM
fast2camciv's Avatar
i allways use the motorola 2.5bar cheap, very effective, and accurate.
phan222001
Aug 17, 2007 05:07 AM
Greg H
Sep 23, 2006 06:58 AM
turbolshatch
Feb 2, 2006 06:06 AM
BoostedJeff
Sep 24, 2004 09:27 AM
qwklude82
Jan 8, 2003 09:43 PM
