MAP seen by ECU
my VAFC tells me that the EMS included with my SC kit is showing the ECU about 90mmHg at full boost. i am surprised it's not at zero. because of this, the VAFC seems to be able to richen it up about 8%, and then i get bogging.
does that 8% correspond approximately to the difference between the ECU seeing 90mmHg and atmospheric pressure? or does the ECU have slightly positive fuel tables as well? or... is the bogging totally unrelated?
any opinions from the MAP experts?
is there a comparable out of band reading for negative values? if i have it at -20% or something to help idle some big injectors, won't that cause it to see more vacuum than possible? like -800mm or something?
Del Sol on Steroids
Nov 25, 2006 04:22 AM
silverCRXTC
Feb 4, 2004 07:32 AM
VTECHGSR
Dec 13, 2001 04:30 PM
