Manual boost controller
Old Apr 4, 2007 | 12:35 AM
Lil_Jon's Avatar
Default Manual boost controller
i have a greddy turbo kit it has a internal waste gate though, the question is can i still hook up a manual boost controller to it to adjust my boost levels.... any help would b great thanx
Old Apr 4, 2007 | 05:43 AM
RudeLude's Avatar
Default Re: Manual boost controller (Lil_Jon)
yes
Old Apr 7, 2007 | 04:38 AM
Lil_Jon's Avatar
Default Re: Manual boost controller (RudeLude)
how woul i hook this up where would i make the lines go to on to the little wastegate thingy on the turbo and one to the blow off ?
Old Apr 7, 2007 | 06:31 AM
motormike40's Avatar
Alot of the controllers have a male fitting on the side, and on the bottom. Take the line that connects from the wastegate and connect to the male fitting on the side, and the bottom male end connect it to the turbo. The installation of it is real simple it just installs on the vac line between the wastegate and turbo. To get it to stay on.. just go to Autozone and get some 1/4 inch rubber fuel line and its a real snug fit over it, but it will stay on even if you accidently jump some train tracks doing 65. Heres the plans, photos and a small diagram to where it installs at if you are lost. Building one works great, cheap and you get ALL the parts at Home Depot. http://www.geocities.com/chmwatson/FAQs/mbc.html
I had one for a year, no problems, no creep, spike, or premature boost. Its just hard to pin point what level you want, it take alot of driving around. Hope this helps, good luck
Modified by motormike40 at 7:43 AM 4/7/2007
Modified by motormike40 at 7:46 AM 4/7/2007
Old Apr 7, 2007 | 07:32 AM
93hatched_projekt's Avatar
Default Re: (motormike40)
Pm sent....
Project_EK
Apr 22, 2009 09:13 AM
craig88crx
Apr 20, 2008 02:30 PM
GOIN V8 HUNTIN
Dec 10, 2006 10:51 AM
