which manifold will directly replace a revhard?
Old Jul 24, 2006 | 02:27 PM
RACEPAK's Avatar
Default which manifold will directly replace a revhard?
hello.
a friend of mine has a no ac revhard manifold (d serise)
he want to replace it to somthing else without changing anything....
is there anyone that make direct replacement manifolds for revhard kits?
thanks
Old Jul 24, 2006 | 02:40 PM
oscarmayer's Avatar
sorry but most likley a trial and error method. i imagine he's msot likley going to have to get a shop to modify his existing dp to work with what ever new one he gets. there is no "one size fits all" in turbo aftermarket stuff.
Old Jul 24, 2006 | 02:52 PM
93CX's Avatar
Default Re: which manifold will directly replace a revhard? (RACEPAK)
whats wrong with his current manifold?
Old Jul 24, 2006 | 02:53 PM
RACEPAK's Avatar
Default Re: which manifold will directly replace a revhard? (93CX)
it cracked after it was welded (lasted 4-5 months)
Old Jul 24, 2006 | 02:57 PM
Boosted2K's Avatar
If it's a B series motor an Inline-pro manifold should work
Old Jul 24, 2006 | 04:21 PM
dpetro1's Avatar
Default Re: which manifold will directly replace a revhard? (Boosted2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K &raquo;</TD></TR><TR><TD CLASS="quote">If it's a B series motor an Inline-pro manifold should work</TD></TR></TABLE>
agreed. i was in tyhe reverse situation. i am using an inlinepro dp with revhard mani on my gsr. it fit perfectly. i think these mani's are pretty much interchangeable. also phil over at spoolin makes downpipes that fit both inlinepro and revhard because these manifolds are so similar.
Old Jul 24, 2006 | 05:09 PM
adseguy's Avatar
Default Re: which manifold will directly replace a revhard? (dpetro1)
If he is cracking Cast iron manifolds he may want to seriously look into motor mounts, putting in a flex section in the exhaust/downpipe if he doesn't have one, or making sure the Downpipe is not stressing itself on the manifold .
99REDGSR1
Jun 12, 2007 08:15 PM
gtcali
Sep 14, 2005 03:11 PM
Jimmy
Jan 3, 2004 06:49 AM
hybridb18
Oct 7, 2002 11:47 AM
