Manifold to fit this flange?
Old Aug 12, 2003 | 10:30 PM
Specialk's Avatar
Default Manifold to fit this flange?
I got this t3 off ebay, its not much but all i can afford right now. Ive been looking at manifolds and have noticed that the flanges for t3 have bolt holes in pretty much a perfect rectangle. The one i have has one of the holes offset a bit and i was just wondering if anyone knows where i can get a mani to work with this or possibly an adapter plate to use with a regular mani. Thanks and heres a pic to show what im talkin about.
Old Aug 12, 2003 | 10:31 PM
lazerus's Avatar
Default Re: Manifold to fit this flange? (Specialk)
that's a chrysler 2.2L turbo, it's basically a T-3 flange with an offset bolt hole, get a pattern of a T-3 gasket, and re-drill the offset hole.
will work perfect.
Old Aug 12, 2003 | 10:36 PM
Specialk's Avatar
Default Re: Manifold to fit this flange? (lazerus)
youre sayin drill a hole in the turbo to make it have the standard configuration. if so thanks i hadnt thought of that.
Old Aug 12, 2003 | 10:40 PM
lazerus's Avatar
Yes. i've used those turbine housings a few times. re-drilling works fine.
Old Aug 13, 2003 | 06:27 AM
legendboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">Yes. i've used those turbine housings a few times. re-drilling works fine.</TD></TR></TABLE>
503_EF9
Nov 13, 2008 11:17 PM
SoHc94
Oct 12, 2008 06:36 PM
pip9
Mar 28, 2004 05:56 PM
EV1L SI
Jul 13, 2003 11:12 AM
smslude
May 2, 2003 02:01 PM
