Manifold ?
Old Jun 12, 2015 | 09:31 AM
the red eg's Avatar
Default Manifold ?
My question is. The goal is to get as close to 600 whp as I can. Do I need a ram horn or will a mini ram work. My major issue on last tune session was back pressure do to manifold and possibly housing. Do I need to step up to the .82 or is the .63 going to be ok for my goal? It made 525@30psi but went lean on e85 do to low fuel pressure, pressure gauge was broken reading 65psi put several other gauges on it and they all said 35psi. I have also been venting from back of block, would I be better off tapping the valve cover and venting from there since back pressure is causing it to blow oil through the can?
Current setup
Benson sleeved 83mm b18c
Co 9:1 Pistons
Pauter rods
Super tech valve train
Victor x
Stock gsr cams
Fuel system
Walboro 255
Id 1000s
Aem rail and reg
Stock lines
Turbo setup
Pte 5858 journal .63 ar
eBay cast manifold (last eBay part left from first kit)
12 x24x3 ic
Act 6 puck max xtreme plate synchro tech trans
Stock axles.
Old Jun 12, 2015 | 11:59 AM
boosted94gsr's Avatar
Default Re: Manifold ?
You will pick up a lot of power from upgrading to a quality ram horn manifold coming from a cast log. Looks like you might need to step up to bigger fuel injectors and pump if you are using e85 with a 600whp goal.
Old Jun 12, 2015 | 12:09 PM
the red eg's Avatar
Forgot to mention I moved somewhere without e85 recently so I will be switching to race gas. Any ideas about the housing is .63 fine or should I step up to the .82?
Old Jun 12, 2015 | 12:13 PM
Charlie Moua's Avatar
mini-ram is absolutly fine for 600whp.
Chances are you'll gain a few more whp north of 6500rpms with a ramhorn manifold but by no means is a mini-ram limiting you on reaching your goals.
warning, mini-ram manifolds sit low so the oil return line will be slightly tricky.
best solution i've found is modifing fittings and using pushlock to reduce amount of fittings required.
Tulo
Jan 19, 2013 07:40 PM
FlewByU352
May 26, 2010 07:57 PM
Si Shane
Apr 10, 2008 10:59 PM
TheShad0w
Apr 1, 2002 06:55 PM
