maintenance job
oil changes. I do a lot more compression tests than usual. Check more often for leaks. That's about it. I mean...what else is there? You couldn't come up w/those urself?
if a small amount of oil leaks out of where the turbine meets the downpipe at start-up...obviously something is wrong, theres a leak...but is it really bad? No smoke out tailpipe and it stops leaking after 2 secs. What is ur opnion on this?
CrazyHondaBoy
Sep 16, 2003 10:13 PM
