Main bearing clearance calculation confusion??
Alright i must be missing something? Using the formula ...
(Inside bearing journal - Outside diameter crank journal) - (2x Bearing Thickness)
One of my examples for my measurements using the thickest blue bearing (.0793"-.0791")
(2.329 - 2.1648) - ( 2 x .0793) = .0056"
honda spec = .0009-.0017
WHAT IS GOING ON??? my clearance is too much! I have checked and rechecked my measurements and i know the crank is in good condition so i am thinking i am doing something wrong?
thanks
thanks
This is the reason I don't use Honda bearing...if the plasti-gauge reads .0015, roll with it. I've build over twenty with .0010-.0015 and they are still living today.
Are you implying to use the marked letters "CCDCC" to clearance this engine? I dont want to be in the position of buying bearings more then once. I want to use oem bearings and this math should be accurate.
Unfortunately i don't have the old bearings as a reference
Measuring with a ball mic?
Measure again... Ive nevedr had any issue with my measurements vs clearance after using them.
Well i re did my measurements today and came out with 2.3252" and based on my main journals this leaves me with only .0018-.0019" of clearance using the blue bearing. I am trying to wrap my head around why i am using the thickest bearing. I recall the previous owner polishing the crankshaft and i did during this build. I am thinking this is why i am using honda blue bearings.
You need to have the block align honed to fix it.
How would the main bore end up being too big in the first place? I don't want to end up having poor bearing crush! This makes me want to measure it yet AGAIN to double check, although this will be my 4th time.
Thanks to eg1834 i didn't torque the mains down when i was checking the bore diameter. I am going to do that tomorrow and hopefully get some more reasonable numbers!
akura404
Jul 31, 2006 01:18 PM
