M&W PRO 10 Help
Old Jun 18, 2006 | 05:19 AM
Turbocivic94's Avatar
Default M&W PRO 10 Help
I connected everything the way it says in the instructions. I connected the ignitor to A21 ICM. Car does not start and its giving me Ignition output signal code.
What's the problem?
Old Jun 18, 2006 | 07:43 AM
Jared's Avatar
are you trying to bypass the ignitor completely?
Old Jun 18, 2006 | 07:54 AM
Default Re: (Jared)
yes
I took the coil and ignitor out of the dist.
I got the ICM pin from ecu to M&W Box. Then from M&W box to coil.
Old Jun 18, 2006 | 07:59 AM
tegedrex's Avatar
Default Re: M&W PRO 10 Help (Turbocivic94)
Hit up Tony1 is my suggestion
Old Jun 18, 2006 | 09:33 AM
BB6-213's Avatar
Bump, Because I will be installing mine soon.
Old Jun 18, 2006 | 09:50 AM
2point2's Avatar
should have went with msd..
subscribed because I hate honda ICMs.
Old Jun 18, 2006 | 12:32 PM
Default Re: (2point2)
well, I spoke to tony and I still cant figure out the problem. I had to put back the factory ignitor in the dist. I did that, car still does not start. I put a factory dist and started right up.
I dont understand why I would need the factory ignitor if M&W does the samething. If the ignitor is in the dist, it still does not get signal from ecu cause signal is going to M&W box. Everything is wired correctly.
I'm getting code for ICM. Maybe I should have bought MSD cause its pissing me off.
DAVE15401
Sep 23, 2007 12:24 PM
rev_it
Jun 6, 2006 03:48 PM
99TurboFerio
Apr 3, 2005 04:31 PM
Redline130
Jul 25, 2001 06:36 PM
