lucas 440 and d16z6 problem
Old Mar 12, 2004 | 04:15 AM
jazz215's Avatar
Default lucas 440 and d16z6 problem
trying to install my lucas 440cc, seems the bottom (very tip) of the injector is to fat. and prevents it from going into the im fully. even when i remove the rubber grommet and orings... it wont go in as far as it should. the top portion fits snug and is in all the way... but the bottom is preventing me from being able to screw down the fuel rail. can i just sand down the tip of the injector? (its the lip that holds the oring in place.) since the oem injector doesnt have the lip on the bottom.
Old Mar 12, 2004 | 04:41 AM
GorData's Avatar
Default Re: lucas 440 and d16z6 problem (jazz215)
Take a Dremel with the Round Tip and start Shaving in there but be careful not to shave to much of it cause then You have to get new Ones.
Old Mar 12, 2004 | 09:22 AM
jazz215's Avatar
Default Re: lucas 440 and d16z6 problem (vteccivicsi92)
im just gonna sand each one by hand.
Old Mar 13, 2004 | 11:06 AM
jazz215's Avatar
i just replaced the whole distributor. i got the car to start, but now it has a really ruff idle... i put -40 for the afc but my a/f guage says thats to lean... so for 1k i put -32 and that makes it stoich. when i drove really slow.. my car seems to backfire alot.. (popping sound). I smell something burning.. and when i looked underneath my car the back half of the cat was glowing red hot... i could see the heat waves coming off it as well. whats going on? someone help me
Old Mar 13, 2004 | 02:27 PM
JdM_y0's Avatar
i dunno, bump 4 u!
Old Mar 13, 2004 | 02:37 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (bluep3)
glowing cats are not good homie....could be right and the excess fuell is getting ignited when the cats hot causeing that. any codes?
Old Mar 13, 2004 | 03:10 PM
jazz215's Avatar
no codes at all. but for some reason my srs light is on full time now. grrr. anyways, i drove it to prospeed imports and got it tuned there... eugene did an awesome job, idles perfect and set to 5psi lol .. (its a start) now i dont have to worry about missing work. tuning somehow got rid of most of the problems. acceleration is so smooth. I went from sub 100hp to 149whp... im a happy camper ..... for now.
Old Mar 13, 2004 | 03:17 PM
dfoxengr's Avatar
Default Re: (jazz215)
thats probably too lean since its getting that hot. also check ur ign. timing
embersanenders
Jul 16, 2012 01:30 PM
DonsEG
Jun 30, 2009 04:18 PM
dohcdelsol
Jul 27, 2008 07:21 PM
hondacivic9099
Mar 5, 2008 07:17 AM
