LSVTEC turbo or LS Turbo
Old Oct 13, 2001 | 12:25 PM
H22CIVIC's Avatar
New User
Default LSVTEC turbo or LS Turbo
I have an LS that I am about to turbo in my EG hatch! Would it be worth my time to drop on a SIR head and make a LSVTEC turbo hybrid?
Old Oct 13, 2001 | 01:26 PM
WykidEH's Avatar
Default Re: LSVTEC turbo or LS Turbo (H22CIVIC)
Turbo it! Look at where you are posting!
Old Oct 13, 2001 | 02:54 PM
H22CIVIC's Avatar
New User
Default Re: LSVTEC turbo or LS Turbo (WykidEG6)
Im posting in Forced Induction! I dont know what you are trying to get at but all I want to know is if it would be worth while to throw on a SIR head on a LS block if it is turboed! I am more of a N/A kind of guy! Help me out!
Old Oct 13, 2001 | 03:48 PM
Leimokei's Avatar
New User
LSVTEC w/TURBo that's a crazy setup...i say go for it, it if dies on you...go get a LS motor....i want to see the dyno on that LS/vtec if you do that...
Old Oct 13, 2001 | 05:08 PM
Type-ARR's Avatar
Default Re: LSVTEC turbo or LS Turbo (Leimokei)
Ls vtec motors are high compression b/c the vtec head is smaller then the ls head.......I know a few people w/ ls/vtec turbo and they have either blown or run like ****. I would look at the compression and get internals for an ls/vtec setup or your just asking for trouble.
Old Oct 13, 2001 | 05:25 PM
Turbolude's Avatar
Default Re: LSVTEC turbo or LS Turbo (ITR-481)
My friend has ls/vtec turbo in his hatch...it is ******* nasty...
Old Oct 13, 2001 | 05:26 PM
Type-ARR's Avatar
Default Re: LSVTEC turbo or LS Turbo (Turbolude)
if its so nasty why does it run 14's?
Old Oct 13, 2001 | 06:01 PM
1.8EG-T's Avatar
I will be able to tell you more in a few weeks. I am awaiting my drag kit for mine. If it runs good, cool. If not, it gives me a reason to build the b17.
Old Oct 13, 2001 | 06:19 PM
paulzy's Avatar
Default Re: LSVTEC turbo or LS Turbo (hybridrex)
wait a couple of months....my block is almost done and the turbo parts are all here. it's a semi built ls/vtec turbo running on a haltech ECU and 20 lbs of boost
Old Oct 13, 2001 | 06:31 PM
bruthaboost's Avatar
Default Re: LSVTEC turbo or LS Turbo (Slow_ass_4dr)
Yeah, same as above. However now thats it's almost done I wish I sleeved the block. That and the oil pump are the only things holding me back from 400+ whp. As the block currently stands 350 will be the upper limit .
Old Oct 13, 2001 | 06:51 PM
Incognito's Avatar
Default Re: LSVTEC turbo or LS Turbo (b18bpwr)
I run a LS/VTEc turbo setup, but I have different pistons. If you're doing turbo LS/VTEC, use a '99-'00 Civic Si (B16A) head. It yields lower compression than a GSR head.
Old Oct 13, 2001 | 08:02 PM
H22CIVIC's Avatar
New User
Default Re: LSVTEC turbo or LS Turbo (Incognito)
Thanks for all the replies!!
Incognito. What are you using for internals? I want to run 12-13lbs of boost on this motor. I have a 99 SIR head with a Type R intake manifold. Any other suggestions as I only want to do this once! It is my daily driver so I need this to be 100% perfect! What size fuel injectors? I have 340cc's. What ecu do I use? Do I just use the stock ecu?
These might sound like stupid questions but I am just getting into turbos.
Old Oct 13, 2001 | 09:16 PM
Homer_Simpson's Avatar
Ls/Vtec turbo doooooooooo iiiiiiiiiiiiiiittttttttttttttt..........
Old Oct 13, 2001 | 10:07 PM
Turbolude's Avatar
Default Re: LSVTEC turbo or LS Turbo (*****rAcEr)
itr-481, after your parents buy your turbo for u come find me and i'll show you how fast my 14 is!! i forgot that 9:1 compression was high.. MORON!!
I seem to recall u got beat by a bone stock type-r by like 2 cars, then you u got pulled over by a cop on a bicycle!!!!!!!!!
Old Oct 14, 2001 | 06:05 AM
Reverend's Avatar
I had a buddy that had that setup in his 93 GSR, and it was easily the fastest honda in town for a very long time, till he got a little boost happy and blew his motor to smitherines trying to run like 16 psi. That was on stock internals. I think it blew because he wasn't watching his EGT and he was driving on the highway trying to "top it out" or some ****.
It can be pretty reliable if you take your time in researching and do it right.
Old Oct 14, 2001 | 06:40 AM
nutsack's Avatar
LOL!
Old Oct 14, 2001 | 11:05 AM
LshatchTurbo's Avatar
New User
Default Re: LSVTEC turbo or LS Turbo (*******)
LS/VTEC turbo is apparently hard core with these guys. They put a Vtec head on and broke in the 11's no problem! Check it out here http://www.tappauto.com/hondapage1.htm My freind and I both run LS turbos in our hatches. He recently did a vtec head swap. At same boost levels and everything, he put down a extra 58hp at the wheels on the dyno at the same boost level, 10psi! Its definaly worth it....but i guess we haev to wait and see how long this motor can hold up. Hope that helps.
[Modified by Zynentech, 8:10 PM 10/14/2001]
Old Oct 14, 2001 | 12:27 PM
Rain_man's Avatar
New User
Default Re: LSVTEC turbo or LS Turbo (Zynentech)
Depending on how much money you have, LSVTEC Turbo might be worth it. If you have tons of money, then go for it, after all you can afford it right? But just remember it is expensive
But if money is a consideration, I'd concentrate on doing the turbo properly (no fmu, rising rate regulator, check valve stuff) and get a hondata and some injectors.
Then reinforce the block by getting it decked and sleeved, along with new rods, pistons and so on and boost that baby.
Remember the main principle on which vtec relies on it's power is high compression and cams at high rpms to make power. High compression is definately a turbo no no (not saying it can't be done) and high rpms on the LS block is bad as well (bad rod to stroke ratio). I personally am one that doesn't like to do thing with a sub-optimal setup.
Old Oct 15, 2001 | 10:27 AM
Incognito's Avatar
My turbo LS/VTEC setup is running a '95 B18B1 LS block with 8.5 to 1 compression JE pistons, with Crower rods. I have ARP head studs, and a blockguard in it. The head is a stock '00 Si head. I'm only boosting 9.5psi (on the street and at the track), and it's pulling in consistent 115 to 116MPH runs (11.8 to 11.9 in my '93 Civic Si hatchback, 2450lbs, on slicks). I'm running a stock '95 GSR ECU, Walbro intank pump, Vortech FMU with the 8 to 1 disc, VAFC, and RC 370cc injectors. I think you'll be fine with the 340's. The car is daily driven. When I made the 11 second runs, all I did was slap slicks on it. The car feels good on the street (break tires loose at will in the first 3 gears, will spin tires in 4th if shifted fast).
Old Oct 15, 2001 | 11:39 AM
H23 Power's Avatar
hmmm, i wish people brought out their 911 turbos to the track by me...always wanted to see that
[Modified by 01GSR, 2:39 PM 10/15/2001]
Old Oct 15, 2001 | 04:47 PM
Full-Race Geoff's Avatar
who built your bottom end terry?
good times, and is that a 60-1?
Old Oct 16, 2001 | 07:43 PM
Incognito's Avatar
Default Re: LSVTEC turbo or LS Turbo (z10 geoff)
This Jamaican dude at a shop in Newark built my bottom end. He seems to know his ****. I hope it holds up Might have to hit U guys up for a LS/VTEC girdle.
The turbo is a 60-1.
Might try to boost higher tomorrow night to get into the mid 11's.
Old Oct 17, 2001 | 10:05 AM
cool stuff. I will be runnign my ls vtec shortly but being away at school sucks...
Ill be home in 5 weeks so if you want a girdle let me know. Did you ever see Emad run last year in his ls vtec? He would drive to the track on his 25" slicks in that torn the **** up white hatch and run 11.1. He swore all over that driving to the track on slicks is the reason he went so fast... hah, total nutcase.
Either way let me know what kinda times you hit at ~20 psi, i dont know if your fuel setup will take that or not tho, is your block sleeved? Keep that ignition way retarded and you should be ok...
Old Oct 17, 2001 | 02:43 PM
H22CIVIC's Avatar
New User
Incognito: What rpm are you shifting at with your setup??
[Modified by H22CIVIC, 11:44 PM 10/17/2001]
Old Oct 17, 2001 | 03:59 PM
Tapp's Avatar
New User
Default Re: LSVTEC turbo or LS Turbo (01GSR)
Yeah, that was a close race.. was only running 12's then. We both ran like 12.40's at 115- beat him by like a hundredth.
