lsvtec turbo
Old Jul 28, 2012 | 07:01 AM
ls_on_boost's Avatar
Default lsvtec turbo
ok ran at the track last night car was sitting for about a month and a half but did start it a few times a week i also drian all old gas and refilled with fresh e85 now at the track i did two good passes everythings fine track sucks spinning the track on slicks but the thrid pass i did a burnout and when i went to lauch car bogged and ran with what felt like no power i came back around to try agian and same thing it did this to me last time at the track i thought is was the dizzy so i changed it car ran good but its doing this agian anyone have any idea what it could be i have data logs of all passes beside running little rich everything looks good temps are 185 iat is 98 map sensor looks fine the old dizzy was a ebay one i bought a oem one so i dont think its that do u think vtec sel is going bad car has oil no intercoller piping is off or popped off idk.
here is videos of the good passes
http://www.youtube.com/watch?v=-0z1O...3&feature=plcp
http://www.youtube.com/watch?v=3r71Z...2&feature=plcp
here is the bad passes
http://www.youtube.com/watch?v=Bj2yV...1&feature=plcp
Old Jul 28, 2012 | 04:02 PM
civickiller's Avatar
Default Re: lsvtec turbo
i only thing i noticed, the first 2 "good" passes had no burnout
3rd pass had burnout and bogged
either dont burnout or burnout and raise launch rpm
Old Jul 28, 2012 | 04:21 PM
Turbo-LS's Avatar
Sounds like my car when I ran a couple weeks ago for the first time with the car on slicks. I had to up the boost and launch control in 1-2 gear and then it stopped bogging.
How long did the E85 sit in the tank and what fuel pump are you running ?
Old Jul 28, 2012 | 09:58 PM
see thats the thing at the same psi in first and rev limit on launch with thrid gear burnouts it never bogged it would actually spin too much we didnt make any changes im thinking something electrical is wrong or a miss fire i think i may be running 3 cylinders when it does this some things loose or connection idk but with the same settings the car was running fine and lauching no bogging nothing
Old Jul 28, 2012 | 10:02 PM
the e85 i drianed it sat for a month and a half but i was letting the car idle a few times a week then drianed it and added new fuel days before i went to the track fuel pumps are a walbro intank 255 and a inline 044 i was thinking maybe a pump went bad but afr on the data logs show dirt rich 10.2-10.98 so i x that out i know when i checked the plugs today plug 1 looked almost closed there gapped to i beleve 15 or 13 im gonna check in the morning
Old Jul 28, 2012 | 10:04 PM
also listen to the motor it sounds completly different when i say its running bad sounds like a subaru or all motor theres no power gottta be a cylinder not running
Old Jul 29, 2012 | 01:27 PM
crvtectim's Avatar
What style injectors/clips are you running? I ask because I remember losing a metal clip (obd0 style) at the track one time, which left me running on 3 cylinders due to the injector being temporarily unplugged.
Old Jul 29, 2012 | 03:01 PM
running fic 2150s all injectors are clipped
Old Jul 29, 2012 | 03:37 PM
92redhatch's Avatar
I use to have this issue because by gm 3bar map sensor would come loose. I'd look at you map sensor
Old Jul 30, 2012 | 04:16 AM
I was think map sensor too but the data log doesn't show any signs of malfuction but I did but it used and had it for a few years I'll just buy a new one I need one anyways for my dd when it's done
Old Jul 30, 2012 | 09:59 AM
92redhatch's Avatar
Just for reference my data log didn't show a CEL or any signs of map failure
Old Jul 30, 2012 | 06:22 PM
hmm ok understand. i just bought a new map sensor but car wont be at the track for some time im sending my tranny to dp for a g force gear set but i put a stock gsr tranny on the car and gonna daily it for a little bit i'll turn the boost back down to like 500ish
95civhb
Sep 2, 2009 07:57 AM
streetlvlhatch
Apr 23, 2004 07:29 AM
Elite Hatch
Jul 12, 2003 04:49 PM
ActiveAero
Feb 17, 2002 07:15 PM
