LSD question
Old Aug 7, 2004 | 07:18 PM
B20 EK's Avatar
Default LSD question
I have a 99 si tranny with a quaife lsd. i have a chance to get a 99 gsr tranny with only 10k miles at a good deal. all i need to know is can i switch the lsd to the gsr tranny? thanks
Old Aug 7, 2004 | 08:04 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: LSD question (B20 EK)
nope.gsr is bigger
Old Aug 8, 2004 | 05:37 AM
B20 EK's Avatar
thanks
Old Aug 8, 2004 | 12:47 PM
Jaker's Avatar
Actually, you can switch the LSD to the GSR tranny, no problem. However, you need to use the Si ring gear with the LSD. Take the GSR diff/ring gear and swap it into the Si tranny, and the Quaife/Si ring gear into the GSR tranny.
You will need to swap some diff bearings around as well. It works.
Old Aug 8, 2004 | 06:55 PM
B20 EK's Avatar
Default Re: LSD question (Jaker)
so if i took it to the local transmission shop they would know how to do it. what are the other things involved besides the ring gear
Old Aug 8, 2004 | 08:26 PM
Jaker's Avatar
Just the ring gear and the bearings. The GSR diff has tappered bearings, and the Si diff has regular bearings.
cluelessmale
Dec 1, 2004 09:45 AM
K20EG
Oct 9, 2003 02:00 AM
cursED
Dec 31, 2002 07:59 PM
cursED
Dec 24, 2002 05:14 PM
