Ls-vtec Turbo - Clearances
Old Nov 19, 2007 | 07:02 PM
randomae's Avatar
Default Ls-vtec Turbo - Clearances
I am a little lost as to what kind of clearances i should have as far as valves and rod bearings for my turbo lsvtec setup. I have heard that looser (bigger clearance) is better for boost how true is this? Could someone point me in the right direction?
Old Nov 19, 2007 | 07:23 PM
mighty137's Avatar
If its an LS block.....then get LS rod bearings..
What ever head u choose to run ( ITR, b16, GSR, b17 etc...) set the valve clearances to manuf. specs.(stock head)
Looser clearance in the rods/main bearings or valve lash??
Old Nov 19, 2007 | 07:42 PM
randomae's Avatar
Default Re: (mighty137)
in the rod bearings..
thanks for your help do far though..
Old Nov 19, 2007 | 07:46 PM
mighty137's Avatar
Manufacture specs unless ur doing something custome...
plastigauge or if u have lots of time to measure with a micrometer. G/L
Old Nov 19, 2007 | 07:48 PM
randomae's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mighty137 &raquo;</TD></TR><TR><TD CLASS="quote">Manufacture specs unless ur doing something custome...
plastigauge or if u have lots of time to measure with a micrometer. G/L</TD></TR></TABLE>
Thank you.
dustin_crxsi
Jan 30, 2007 01:00 PM
Spence
32
Sep 29, 2005 03:32 PM
crxhybrid85
Nov 19, 2004 09:49 AM
b16vtecsol
Apr 28, 2004 04:01 AM
lsvtec101
Jan 14, 2004 05:19 PM
