ls/vtec setup need help?
Old Dec 3, 2006 | 01:19 PM
jgrogan's Avatar
Default 2.0l turbo setup?
whats up. I am about to be finished with my motor. I wanted to know some thoughts to see what I can expect and need a little advice. This is my first build and want to do it right. going to be street and drag car for now till I can get another car then mostly drag car.
Bottom end: sleeved ls 84mm golden eagle block, 9:2:1 forged pistons,eagle rods,arp rod and mains, vtec water and oil pump
top end: b18c with type r cams, ferrea valves,brian crower springs and ti retainers, pnp and 5 angle valve job and edelbrock cam gears, victor x mani
turbo setup: inline pro cast ss mani, precision sc61 turbo, tail 50mm blow off valve,spoolin performance downpipe and charge pipes
I think thats it that I have. On the car already is pit ti 2.5in exhaust. I also have driveshaft shop stage 2 axles and going to use hondata.
The questions that I have is what size wastegate, intercooler, injectors,and clutch
Modified by jgrogan at 7:14 PM 12/4/2006
Modified by jgrogan at 7:16 PM 12/4/2006
Old Dec 4, 2006 | 04:15 PM
jgrogan's Avatar
Default Re: ls/vtec setup need help? (jgrogan)
no help
jdmb16turbo
May 13, 2009 07:00 PM
Civic
Sep 3, 2003 04:25 PM
MIKES
Nov 7, 2002 03:31 PM
xTeg
Jul 22, 2002 09:58 AM
