ls/vtec 400hp
Old Apr 19, 2007 | 08:04 PM
sc34dx's Avatar
Default ls/vtec 400hp
Hi everyone i am fairly new to this forum and i wanted to get some information on my set up...i have searchd other sites and googled the living crap out of my question...!!!lol well i will start off with my question: can i make 400whp with my sc34 48 a/r on pump gas? i have bin reading and looks like my best bet is geting the 63 a/r for it...but i would like to know what #'s you guys think i could get out of my 48 a/r with out stressing the turbo to much....well here is my set up if it helps...
b18b1:
stock sleeves
eagle H beams
cp 81mm 9:1 pistons
clevett 77 bearings
ls crank
golden eagel headstuds
golden eagel ls vtec conversion
b16a head:
skunk 2 valve springs and retainers
b16 cams
buddy club cam gears
turbo set up:
percision sc34 48 a/r
percision 1000cc injectors
percision 650hp intercooler
inline pro cast manifold
tial 38mm waste gate
tial bov
3" turbo back
let me know wat you guys think....???? or
Old Apr 19, 2007 | 08:36 PM
A.E Motoring's Avatar
Default Re: ls/vtec 400hp (sc34dx)
gonna need a bigger a/r than .48, yea quicker spool, but its gonna choke up top
Old Apr 20, 2007 | 04:56 AM
mike1114's Avatar
Default Re: ls/vtec 400hp (Dual Cam Racing)
I had a t3/t4 57 trim .60/.48 and hit 400whp at a little over 20psi but like said it was sorta starting to choke up top.
Personally I freaking loved it, it spooled so quickly, I had over 150ft-lbs of torque by 3000 rpms!! I had a .63 a/r at first and switched.
I would do it again.
not sure how the sc34 compares to it but if it flows around the same amount it will work.
Old Apr 20, 2007 | 05:42 AM
sc34dx's Avatar
Yea the sc34 is a t3/t4 57 trim .60/.48 so if it makes anywere between 375 and 390whp ill be good to go.... plus my real goal is to run 11.5 i could run faster but i dont wana have to get a cage and all the other bs for the track, when you run 11.4 or faster.....plus im on stock sleeves so i want the block to hold up....
ppiart
May 26, 2011 09:09 AM
T3T4Honda
Sep 27, 2008 01:07 PM
sc34dx
Jun 11, 2007 03:37 PM
92civicsib18c5
Sep 26, 2005 09:54 AM
imissmyfc3s
11
May 22, 2005 06:10 PM
