ls turbo question
Dc thanks for the info my swap is going in a crx so i need to convert to Obd1 to run all my stuff like dizzy evu and injectors. Do you know anyone with some 750 cheap
http://www.hondamarketplace.com/
2) Yes, depending on the size of your turbo. You are more than likely going to need a boost controller and an aftermarket MAP sensor (again, search). LS heads generally make less power per psi than VTEC heads, thus, you may need more pressure than the 10 psi wastegate spring is gonna give you.
I have a jdm t3 t4 charger now going on my build it is 57 trim and I wanting to run around 250 300 horsepower with my 450 cc injrctors will this work and be a good daily driver
The 450's will net you the 300 whp, but will put them at a high duty cycle. 550 cc's would be more suitable.
As far as the psi, the efficiency of your setup will determine how much psi it will take to reach 300 whp. I highly doubt that 8 psi will do it anyway, with that particular turbo.
Invest in a good manual boost controller and aftermarket MAP sensor.
No, take it to a reputable tuner, put it on the dyno, and shoot for your 300 whp goal. As stated before, your tuner will use whatever psi your setup will give him to make 300 whp.
g0tgot
Sep 17, 2008 12:33 PM
captainjdog
Sep 2, 2004 04:39 PM
