ls turbo
Old Oct 31, 2006 | 05:45 PM
14bHatch's Avatar
Default ls turbo
i want to put an ls b18 in my 94 hatch and was wondering where i could find a good deal on an engine and tranny combo (with a harness)? and would a 14b be too small of a turbo for an ls? thanks for the help in advance guys!
Old Oct 31, 2006 | 05:58 PM
I Have an STD's Avatar
wrenchin'
Default Re: ls turbo (14bHatch)
wow holy **** man...... https://honda-tech.com/zerosearch there is humongous wealth of knowledge on this site. it is not our jobs to find this information for you. it is your job to find it, thats why the word SEARCH is highlighted in red at the top of the screen. welcome, NOOB
Old Oct 31, 2006 | 07:35 PM
mjturboshop_net's Avatar
If you are going to keep that engine stock that turbo will be definitely a good choice for you, since the 4g63 2.0 Mitsubishi engine can spool that turbo up at around 3500rpm your are probably looking at around the same spool up time since your running higher compression. Also that turbo is good for up to 16psi which will be more then enough.
Old Nov 1, 2006 | 02:37 PM
wrenchin'
Default Re: (mjturboshop_net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjturboshop_net &raquo;</TD></TR><TR><TD CLASS="quote">If you are going to keep that engine stock that turbo will be definitely a good choice for you, since the 4g63 2.0 Mitsubishi engine can spool that turbo up at around 3500rpm your are probably looking at around the same spool up time since your running higher compression. Also that turbo is good for up to 16psi which will be more then enough.</TD></TR></TABLE>
uhhh, dont listen to this guy. do some research. oh and by the way. ive owned 4 different Ls turbo setups, if you need any advice
Old Nov 1, 2006 | 02:48 PM
banmeagain's Avatar
Default Re: (I Have an STD)
cuntface the 14b is too small by factor of 2
go no smaller then a large t3 like 60/63
t3/4s are best for ls
Old Nov 1, 2006 | 02:55 PM
dmotoguy1's Avatar
Default Re: (banmeagain)
the 14b is definately on the small side.. BUT it'll do the trick if you are on a budget.. check out the turbo LS thread.. its like 200 pages of ls turbo info..
as for finding a cheap swap, you are going to want to find a local forum or craigslist or something.. shipping is expensive, look around and you can find good deals..
I'd suggest getting an ls longblock and a b16 or gsr tranny if you have a little extra cash..
Old Nov 1, 2006 | 04:42 PM
blackeg's Avatar
Default Re: (dmotoguy1)
b16 tranny is too tight for an ls motor you plan on driving on the street at all. gsr trans with turbo ls was a great combo when i was making about 240whp.
14b is a little small, just means you might need to run more boost to make desired power goals, which will result in more low/midrange tq probably.
good turbos for stock ls motors are
t3 60 trim or super 60
t3t4 50 or 57 trim (precision sc50,sc34)
gt2871, gt28rs
just a few common ones.
you cna probably use a 16g also with good luck
fastguy8
12
Sep 2, 2006 07:24 AM
jay_reflex
Jun 13, 2005 10:54 PM
94SHOWLS
Feb 16, 2005 12:08 PM
ThrowSomeDs
Dec 15, 2004 07:46 AM
Integra717
May 19, 2002 11:22 AM
