LS-T for under 9000...
Old Mar 30, 2003 | 10:23 AM
Jamison182's Avatar
Default LS-T for under 9000...
Including the price of the car, is it possible to build a well running LS-T for under 9 or 10 grand? For you guys who already have LS-T's, was it worth the time and cash?
Old Mar 30, 2003 | 10:36 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: LS-T for under 9000... (Jamison182)
Yes, it is possible with a cheap car James.
Old Mar 30, 2003 | 10:43 AM
Jamison182's Avatar
Default Re: LS-T for under 9000... (integra707)
But if I get a cheap car, that means high miles. Turbo+high milage = bad
ps. CHAUMPEIGNYA!!!
Old Mar 30, 2003 | 11:00 AM
gritsak's Avatar
its possible if you find the right car...my friend is selling a 94 ls for around 4k..i cant remember the milage but its around 100-150k..a low milage ls block is pretty cheap (under 1000) and thats only if the other blows...then at about 4k for turbo kit and asseccories and you are right around 9k
high milage and turbo doesnt have to be bad..just do a compression check before you buy the car, if that checks out in good and theres no other signs of bad matinence or internal/seals problems you should be fine
Old Mar 30, 2003 | 11:25 AM
MaxBoost's Avatar
New User
Default Re: LS-T for under 9000... (gritsak)
92 civic cx $1750
Complete LS Swap $1500
Sell LS Tranny $350
Buy B16/GSR tranny $450
Pistons/Rods/Blockguard/Bearings/Waterpump/Headgasket/ETC/ETC $1500
MaxRev Turbo kit w/ Hondata option $2800
$8350
You still need a bunch of ****, but that's for you to figure out, remember the fuel system, some suspension, wheels, tires, misc stuff for the engine build, like 3" Exhaust, clutch, etc.. You can do it with 9000 no problem but better to get a hatch, swap the LS with b16 or GSR tranny and then slowly save up the money to turbo the bitch..
If the hatch is a cx, you have some slicks, you can run anywhere from high 12's to low 11's depending on your power output and suspension.... good luck.
Old Mar 30, 2003 | 12:00 PM
Jamison182's Avatar
Default Re: LS-T for under 9000... (MaxBoost)
Coo, thanks for the help guys. MaxBoost, your car is amazing.
DB1_559
Jul 17, 2006 12:52 PM
Jesseman445
Aug 9, 2005 08:38 PM
jeffchaisi
Dec 18, 2004 11:38 AM
Dream
Jan 29, 2004 09:07 PM
josups
Jan 19, 2003 07:08 PM
