ls rods in d16y8
Old Jul 9, 2002 | 02:49 PM
DXturbo's Avatar
Default ls rods in d16y8
i was wondering if the ls rods will fit in a d16y8 block? if it does what is required to make it fit? one last thing, would je pistons and shotpeened ls rods be good for a mild turbo setup (7psi)? thanks... sorry for so many questions.
Old Jul 9, 2002 | 03:00 PM
Replica_Racer's Avatar
Default Re: ls rods in d16y8 (redsi37)
I have a similar setup in d16z arias pistons with ls rods. The machine shop did some work on the rods to make them fit. They narrowed the big end I belive cant remember correctly. Anyhow I boost 9psi daily, but my car still needs to be tuned.
Old Jul 9, 2002 | 03:57 PM
Hybrid's Avatar
Default Re: ls rods in d16y8 (turboorangecx)
You can run 10psi on your stock rods if your tunned good.................no boost spike.
Old Jul 9, 2002 | 04:25 PM
CovertFI's Avatar
Default Re: ls rods in d16y8 (Hybrid)
what factory rods are the strongest? that can be matted to fit the d16
Old Jul 9, 2002 | 04:27 PM
dohcsideSi's Avatar
Default Re: ls rods in d16y8 (CovertFI)
just a little machine work oh...... i have 3 sets for sale
Old Jul 9, 2002 | 06:59 PM
DXturbo's Avatar
Default Re: ls rods in d16y8 (dohcsideSi)
thanks for the replies. i guess i will be doing this setup then. how much do you want for the ls rods? do you guys know if any other rods might work? ie... typeR or gsr rods.
[Modified by redsi37, 4:00 AM 7/10/2002]
Old Jul 9, 2002 | 07:02 PM
DXturbo's Avatar
oh what bearings would i use? d16 or ls rod bearings. thanks!
Old Jul 10, 2002 | 08:26 AM
Are you going to assemble it? I let the machine shop (RPS in torrance) put together the bottom end.
Old Jul 10, 2002 | 08:27 AM
DSF's Avatar
DSF
D16. LS's are too wide.
Old Jul 10, 2002 | 08:36 AM
VTC_CiViC's Avatar
B18A/B, B16A. BTW D16A1/ZC rods are a good fit and stronger than more modern D16 rods too
Old Jul 25, 2002 | 01:25 AM
00civicvtec's Avatar
Default Re: ls rods in d16y8 (VTC_CiViC)
Anyone know what the machine work to the LS rods usually runs? I'll probabally stick with my ZC rods, but I'm just curious...anything is better than my toothpick Y8 rods
If I could find a set of LS rods for really cheap, and the machine work didn't cost much, I might use 'em...
Old Jul 25, 2002 | 12:33 PM
M.A.R.C.'s Avatar
how much you want for a set? I'm considering the whole LS rod setup. since I might have a spare block soon.
adam00
Welding / Fabrication
24
Dec 31, 2009 01:25 PM
RACEPAK
Jul 14, 2007 06:49 PM
JUN-DA6
Aug 20, 2005 11:05 AM
S9i1R
Mar 23, 2004 09:01 PM
