LS or GSR tranny
Old Jul 16, 2006 | 02:52 PM
Lmgrcivic's Avatar
Default LS or GSR tranny
I have a complete stock LS motor turbod I want to know what everyone is useing for a tranny on the same setup.
Old Jul 16, 2006 | 03:14 PM
slodc2's Avatar
go w/ a gsr...ls gears are too long
Old Jul 16, 2006 | 03:36 PM
adseguy's Avatar
Default Re: LS or GSR tranny (Lmgrcivic)
if it's a BONE stock LS from the valve cover to the oil pan the BEST tranny is.............(drums).....The LS tranny!!! As it stay perfectly in the powerband of an LS. As soon as you put cams, port the head, IM, and other things then you may want to look at a dyno graph and see if the GSR tranny will help out
Old Jul 16, 2006 | 03:48 PM
Boostage's Avatar
Default Re: LS or GSR tranny (adseguy)
LS tranny is the best for a street car. b16 and GSR for race cars.
Old Jul 22, 2006 | 10:11 PM
Lmgrcivic's Avatar
Default Re: LS or GSR tranny (Boostage)
my motor is bone stock just turbod
but with the 22 in slicks I ran a 11.6 and with the 24in slicks I ran a 12.1 I dont really understand it
Old Jul 22, 2006 | 10:25 PM
turboedc2's Avatar
i'd go wit the gsr more acceleration...
Old Jul 22, 2006 | 10:48 PM
weiRtech's Avatar
OG Fabricator
i have both trannies for a 93 integra gs and gsr. the difference is quite a bit while you are shifting. it is a 93 gsr motor so with the longer gears it would drop out of vtec inbetween shifts which isn't what i wanted. as mentioned above i think it is where your power band is tuned is how you should decide. i have to put new syncros in the gsr tranny and when i do that i plan on swapping out the 5 gear from the gs for highway driving.
can anyone tell me if the snycros will be compatible? the gs tranny has had a fresh rebuild before i got it.
Old Jul 23, 2006 | 12:41 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">LS tranny is the best for a street car. b16 and GSR for race cars.</TD></TR></TABLE>
Old Jul 23, 2006 | 12:50 PM
Boostage's Avatar
Default Re: LS or GSR tranny (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Jul 23, 2006 | 12:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Elaborate on why it's better for a street car, foo.
Old Jul 23, 2006 | 01:05 PM
Boostage's Avatar
Elaborate on why it's better for a street car, foo. </TD></TR></TABLE>
No need to, Everyone on HT loves to argue b16 vs b18,High c/r vs Low, LS tranny vs Vtec tranny. in the end whatever works best for you has NOTHING to do with numbers in a calculator and the LS tranny works better for me in my application than a b16 or GSR tranny. so in my opinion LS makes the better Street tranny.
Old Jul 23, 2006 | 04:00 PM
JDMs1eeper's Avatar
LS tranny all the way
Unless you wanna, shift to 5th at 1/8th mile
Unless you wanna, revv to 10,000rpm
Unless you wanna, run 25-26" tires
Old Jul 23, 2006 | 04:23 PM
Spec R's Avatar
Default Re: LS or GSR tranny (JDMs1eeper)
its all about torque multiplication man.
multiply your FD gear ratio, to whatever gear you're in, to the torque at that particular RPM.
Old Jul 23, 2006 | 07:17 PM
JDMs1eeper's Avatar
B16/B18c5' trannys are geared to accomodate a power curve for them
GSR trannys are geared to accomodate a power curve for them.
LS trannys's are geared to accomodate a LS's power curve
Tight trannys are tight to accomodate the lack of lowend power. They also revv very high.
Do you know a LS or B20 will not like, nore make much power above 6,000 in stock form. You add boost to the matter and just like all motors be more likely to have valvefloat at even stock redline. A Vtec tranny is geared to accomodate a high rpm motor that makes power in high rpms.
Actualy I personaly liked the LS tranny on my 550whp CRVtec, It made it much more streetable. A tight tranny will make the power band ramp too quickly for your tires to keep up. So not only will you have more traction problems increase but you'll also run outta gear well before the end of the track.
Modified by JDMs1eeper at 11:30 PM 7/23/2006
Old Jul 23, 2006 | 08:58 PM
quicksilver1689's Avatar
i ♥ snails
the gsr tranny is good for almost every application has nice tight gearing but its not too rediculously agressive so its good for street and will give u an edge over the ls. highway cruising with anything otherthan an ls tranny is dreadful.
Old Jul 24, 2006 | 06:37 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">LS tranny all the way
hahaha.
if making decent power on an ls with a gsr trans i think you might wind up shifting into 5th at the top of the 1/4. not something to look to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote"> it is a 93 gsr motor so with the longer gears it would drop out of vtec inbetween shifts which isn't what i wanted. .</TD></TR></TABLE>
right now i have an ls trans on an lsvtec, and if i shift at about 8k, i drop back into gear around 5500, so i stay in vtec and also in full boost the entire time. something else must have been going on, or you set your vtec way to high
Krucial_Ek9
Apr 11, 2008 09:25 PM
ppg97ek
Sep 4, 2007 01:51 PM
JDubya
Jul 3, 2003 10:04 PM
abs0lutexer0
Apr 30, 2003 11:10 PM
94acurals
Aug 19, 2001 05:41 PM
