ls b18 a turbo
Old Sep 15, 2010 | 01:43 PM
judd_123's Avatar
Default ls b18 a turbo
I building a bottom end with stck crank eagle rods and probe forged pistons. I also got a crower top end I thinking about using as well but the cams are all motor cams how would tjey do with a turbo and how many pounds of boost can I run on a daily basis safely with no problems. Or is tjwre anything else I need to put in my motor while I b7ilding it to make it a little stronger
Old Sep 16, 2010 | 03:43 AM
judd_123's Avatar
Default Re: ls b18 a turbo
Any help ????
Old Sep 16, 2010 | 03:59 AM
CPT Del sol's Avatar
What power r u trying to make?
Your Budget?
Old Sep 16, 2010 | 06:16 AM
judd_123's Avatar
I already got the turbo and stuff. All I like is buying the bearings and rings and it ready to be put togethwr. I was wanting to run 8 pSI daily driver. Do you think my bottom end will be alright or do I need to add to it and also stage 2 crower all motor Cams be alright or should I swap em or buy turbo Cams.
Old Sep 16, 2010 | 11:39 AM
spawn_616's Avatar
wow spelling and caps,8psi on what turbo?can range quite abit
Old Sep 16, 2010 | 01:38 PM
judd_123's Avatar
T3 t4
Old Sep 17, 2010 | 12:58 PM
judd_123's Avatar
Need some help on turbo build
Old Sep 17, 2010 | 03:21 PM
rat city rex's Avatar
Originally Posted by judd_123
T3 t4
lol
Old Sep 17, 2010 | 03:49 PM
nonpoint986's Avatar
so t3 t4 huh... sounds like a turbo out of a 911 lol
Old Sep 17, 2010 | 03:56 PM
viera's Avatar
damn bro double check ur spelling its hard to understand what r u trying to say. 8psi on ur set up is ok. yes, u can use N/A cams on a turbo set up if that is what ur asking.
Old Sep 17, 2010 | 09:23 PM
judd_123's Avatar
Viera thanks for the help I posting off my Droid so sometimes it don't spell worth anything so do you think the setup I will be building will be alright my pistons are 81.5 mm. The spring in my turbo setup is 10 pounds is thatsafe enough and how you think my all motor Cams will do in that motor being turbo charged.
Old Sep 18, 2010 | 11:19 AM
civicjunkie17's Avatar
what size t3/t4? and yes the allmotor cams will be fine
Old Sep 18, 2010 | 02:46 PM
judd_123's Avatar
I not real sure I bought it from a friend two days ago. Would I need head bolts or factory be alright to use with head and with Cams and turbo
Old Sep 22, 2010 | 07:31 PM
judd_123's Avatar
Bump for help. What would be horsepower with my set up on ten pounds of boost
Old Sep 22, 2010 | 08:00 PM
boostedls92's Avatar
With my set up
57mm trim
stock block
stock head
11psi
220-240ish whp
so with some cams and other goodies expect a bit more
Old Sep 24, 2010 | 09:09 AM
judd_123's Avatar
I going with a little bigger bore as well do Yall think I need arp head bolts as well or will it be alright with stock ones on it
judd_123
Sep 15, 2010 08:47 AM
sonne_side
Feb 4, 2009 08:35 PM
Gamefreak0109
Jun 9, 2007 07:34 AM
97turboteg
Dec 16, 2005 03:12 PM
JDMPARTS4U
May 30, 2002 11:03 PM
