Low oil pressure!
Old Jan 19, 2012 | 10:37 AM
JDMCIVIC919's Avatar
Default Low oil pressure!
Recently ive been having low oil pressure on my boosted jdm b16. When warmed up at idle its at like 7psi and a 3k its at 42psi. At idle it use to be at 15 but dunno what happened. I also cant hear vtec might be me but it cant hear it or its really hard to hear. Is there a way to check if vtec is engaging? Also will low oil pressure cause loss in power? Car feels a little slower than how it use to.
Old Jan 19, 2012 | 10:40 AM
DDTECH's Avatar
Default Re: Low oil pressure!
Generally speaking, what is the WOT oil pressure?
The bearings dictate alot on how the oil pressure is .. so it really depends.
Old Jan 20, 2012 | 11:20 AM
alperx's Avatar
instead of checking if vtec engages or not, check why your oil pressure is low.
1. oil pump
2. bearings
3. is there oil in the engine ?
Old Jan 20, 2012 | 12:02 PM
Steeve_Civic's Avatar
Have a an oil radiator?
Old Jan 20, 2012 | 12:22 PM
rich7777's Avatar
9/10 times its the oil pump. When you start the car up from cold does your oil light stay on for longer the usual ? If so take the pump off and inspect it internally... Something probably pass through it and scored it badly.
Old Jan 20, 2012 | 01:21 PM
scottdh20's Avatar
Similar to my problem
http://www.d-series.org/forums/gener...build-not.html
PH3593A
11
Jul 19, 2023 02:36 AM
aznd87
Nov 6, 2006 01:32 PM
wezzel19
Oct 9, 2006 09:05 AM
H22T94
Jul 10, 2004 11:27 AM
vti-R
Jan 31, 2002 05:06 AM
