Low compression on cyl 1 need help
Old Mar 15, 2009 | 06:03 PM
JRoX85's Avatar
Default Low compression on cyl 1 need help
Ok so I recently boosted my 94 integra. It has a jdmb16 and a built gsr head Well now I am layin down 220whp on 8lbs, but upon doin a dyno tune found that cylinder one has very low compression and the bottum end of my motor is stock.
here are my comp levels
cyl 1=160
cyl 2=200
cyl 3=210
cyl 4=210
After comp test we stuck a snap-on camera into block. cyl walls looked fine and pistons had minor carbon build up but otherwise looked normal. so upon a leak down test I found air to be blowing out of my intake TB and exhaust. I believe whoever built my head did not seat my valves correctly or do a proper valve job. valve springs and retainers are crower. Would my assumption be correct on what might be the cause of my comp problem? This is my first Honda so I need some help.
Thanks
B18C5_VTEC
Oct 8, 2007 02:54 PM
2000siturboR
Sep 20, 2007 02:00 PM
street dreams
Nov 21, 2004 04:48 PM
the.hamburglar
May 7, 2004 07:00 PM
pinota
Aug 21, 2002 05:16 PM
