lovefab shorty on h22??? problems
Old May 14, 2005 | 05:58 PM
98 blacksh's Avatar
Default lovefab shorty on h22??? problems
i have a 97 prelude and i just got a lovefab shorty mani, looks great , tough to get on the studs but did it, anyway if i put the turbo on with the compressor housing on the driver side the impeller is sucking in the harness for my alternator, but if i switch it around the way i believe it is supposed to go the other way, the housing hits the block where the front motor mount used to be , the only thing i can think of is that you have to chisel the block a little bit or something anyone with any insight please help
Old May 14, 2005 | 07:27 PM
98 blacksh's Avatar
Default Re: lovefab shorty on h22??? problems (98 blacksh)
up
Old May 14, 2005 | 08:59 PM
98 blacksh's Avatar
up again help me please
Old May 15, 2005 | 07:47 AM
98 blacksh's Avatar
someone has to have this manifold and know
Old May 15, 2005 | 08:23 AM
1Bar GSR's Avatar
If you havnt noticed on a drag manifold and some others you have to grind some of the block away just use a dremel and slowly do it until you get where you need it just make sure you dont go to far into the block ;-)
Old May 15, 2005 | 09:05 AM
98 blacksh's Avatar
Default Re: lovefab shorty on h22??? problems (1Bar GSR)
thanks
Old May 15, 2005 | 09:43 AM
s2kdre's Avatar
thats a common problem with every honda motor, dont be scared to shave the block
Prudz_lude
Oct 19, 2009 06:14 AM
snaileg
Jun 12, 2009 12:34 AM
93H22ACX
Jan 27, 2005 09:07 AM
acr91
Apr 6, 2004 05:20 PM
nickg11111
Feb 25, 2002 02:22 PM
