Lost the Link to an Oil Feed Fitting for Block
I bought one of these a while ago. Looked pretty cool, I never used it though. I suggest buying Stan's $25 setup. That's what I'm currently using. Has everything you need. Although, if you're going to use your stock oil pressure sender, you're going to need one more bspt female to npt male. He could probably throw one in for cheap. I had one laying around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> Firewall Oil Supply Distribution Line Kit
Provides a multi-port oil pressure outlets for all your accesories such as turbo feed line, oil pressure gauge, oil temperature sender and etc.
Comes with an extra plug to securely close un-used outlet.
$ 25</TD></TR></TABLE>
My setup:
My setup:
totsie7944
May 1, 2008 04:52 AM
