Loosing compression
Old Apr 11, 2002 | 11:09 PM
SlowB16's Avatar
Default Loosing compression
Ok last time I had my comp checked it was : 190, 190, 185,185. This is in a b16 first gen. I know these #'s are low. I put my turbo in last weekend and I was wondering if I am going to lose comp a lot faster now that I am boosting. I am boosting about 5-7 lbs BTW. And, is there any way to "pro long" the life of your piston rings? Im thinking not, but worth a try. Thanks for your input, Matt.... My main concern is how long will my engine last for.
Old Apr 11, 2002 | 11:20 PM
SIK IN DA HED's Avatar
New User
Default Re: Loosing compression (SlowB16)
you increase the wear and tear on your motor most definitely when you boost. my compression readings are bad enough as it is since i boosted. just dont abuse your motor too much.
Old Apr 12, 2002 | 08:48 AM
SlowB16's Avatar
Default Re: Loosing compression (dlplayboy)
SOunds good!! Thanks
capmcatastrophy
Jun 2, 2010 07:06 PM
GdmLaz
Jan 28, 2008 10:16 AM
Drizzo
Aug 16, 2005 02:00 PM
s0liDyNe
Jul 19, 2003 10:24 PM
