LOG style h22 manifold
Old Apr 27, 2005 | 10:29 PM
greatbiggiants's Avatar
Default LOG style h22 manifold
I need some options for a manifold for a civic h22 swap. i know rev hard and
Gen Drag make ones. this would be for a low boost street setup 5-7psi.
Does Love fab make a log style. I need to start buing some parts, going to be runing a stock block and head. Aiming for like 230-250hp or am i dreaming.
Old Apr 28, 2005 | 06:59 AM
Sam1am26's Avatar
Default Re: LOG style h22 manifold (greatbiggiants)
Yeah LoveFab makes a log-style manifold called the "Shorty"... I'm running an FMax manifold... I know it would definitely fit in a civic because I bought it from someone who had an FMax prelude kit in there civic...
This is the best pic I could find of it installed...
Plenty of room and I'm running a full-size radiator and both huge stock fans...
Old Apr 28, 2005 | 07:22 AM
oxSLEEPERxo's Avatar
Default Re: LOG style h22 manifold (Sam1am26)
spoolin makes one
Old Apr 28, 2005 | 07:24 AM
graphic's Avatar
what type of DP are you using w/ that fmax log manifold??
cause i have the same manifold but with the fmax- DP and the wastegate dupe is way too short like 1/12in or so..
Old Apr 28, 2005 | 11:55 AM
Sam1am26's Avatar
Default Re: LOG style h22 manifold (graphic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">what type of DP are you using w/ that fmax log manifold??
cause i have the same manifold but with the fmax- DP and the wastegate dupe is way too short like 1/12in or so..</TD></TR></TABLE>
Oh yeah, the fmax downpipe/manifold/wastegate is a closed loop setup that the puts the dumptube strait into the downpipe... I had the dumptube flange in the downpipe cut off and welded shut and then I'm just using flexpipe as a temporary dumptube right now...
Old Apr 29, 2005 | 07:24 AM
graphic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">
Oh yeah, the fmax downpipe/manifold/wastegate is a closed loop setup that the puts the dumptube strait into the downpipe... I had the dumptube flange in the downpipe cut off and welded shut and then I'm just using flexpipe as a temporary dumptube right now...</TD></TR></TABLE>
happen to remember the I/D of the flex tube that you used??
Old Apr 29, 2005 | 04:18 PM
Sam1am26's Avatar
To be honest I can't remember... I just measured the flange that came off the wastegate...
trickeng
Oct 14, 2005 02:41 PM
meltman1234
Sep 30, 2005 05:37 PM
jbell
Oct 8, 2004 12:28 AM
KTeller8
Jun 13, 2002 09:29 AM
snt78
Apr 8, 2002 11:55 PM
