a little turbo advice please
Old Sep 29, 2002 | 04:01 PM
wanabecivicex's Avatar
Default a little turbo advice please
alright, i have already bought my pistons(8.5:1), rods(eagle), bearings(acl), radiator(del sol), clutch, turbo kit (revhard stage2), injectors(450cc dsm) for a b18b motor, im lookin to boost around 18 lbs, what else should i get or what is wrong with my setup now?
thanks your help
Tanabe Wanabe Civic
Old Sep 29, 2002 | 04:10 PM
sutrusu's Avatar
Default Re: a little turbo advice please (wanabecivicex)
FUEL SETUP
get standalone!!! dont even consider that FMU for 18psi!!!!
Old Sep 29, 2002 | 04:25 PM
98civicEX's Avatar
Default Re: a little turbo advice please (sutrusu)
FUEL SETUP
Exactly, but more emphesis on FUEL SETUP!!!
Old Sep 29, 2002 | 06:01 PM
Default Re: a little turbo advice please (98civicEX)
you guys like hondata? i was thinkin about going with that
Old Sep 29, 2002 | 06:03 PM
and how do you guys feel about running the del sol radiator? do you think it will be enough cooling? also, do you think the dsm injectors will be enough?
Old Sep 29, 2002 | 06:12 PM
ekb18c's Avatar
Hondata is great system (bang for the buck).
And your stock radiator should be fine.
The del sol radiator (only if it's a duel core) would be better, but you should be fine with your stock ex radiator.
HTH
Old Sep 29, 2002 | 07:34 PM
Default Re: a little turbo advice please (ekb18c)
you think 450cc injectors will be enough to run 18 lbs of boost?
Old Sep 29, 2002 | 07:41 PM
BlueSi2k's Avatar
no you're gonna need bigger injectors unless you increase fuel pressure but i wouldn't recommend that...
Old Sep 29, 2002 | 07:48 PM
Default Re: a little turbo advice please (BlueSi2k)
ok, well, ill be running 9psi for a while, do you think 450cc will be fine for that or too rich?
Old Sep 29, 2002 | 07:49 PM
BlueSi2k's Avatar
450 should be fine for 9psi as long as your fuel setup is up to par
97dc2
Jan 1, 2006 10:03 PM
sol2nr
Feb 27, 2004 12:15 PM
Huee
Feb 23, 2004 11:23 AM
EH3_Si
Nov 18, 2003 12:38 PM
