little bog on take off?
Old Jan 4, 2006 | 08:04 PM
93civciv's Avatar
Default little bog on take off?
I just recently put a turbo on my b16 and i took it out for a spin and it ran awesome...could not have had a better run around..anyway...towards the end of my second run around my neighborhood....
it was a little hard to get out of neutral with out my car wanting to almost die...it would be close and i would let off the gas and put it in neutral and my cars idle would surge...from like 1000- 1500....
and my normal vacuum is usually at 20 or more but when my idle does that its at 10 and rises to like 5 and comes back...rises..etc....
I changed my pcv valve and it fixed the problem for a little bit but then the idle would do it again but only a few times and then i could drive it again...
could it be a small vacuum leak somewhere??
I have a code 41 coming up and i have tried 3 dif. used o2's but i am going to buy a new one...could this be my prob???
sorry so long...just thought i would get it all out there..
later
Old Jan 4, 2006 | 08:11 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: little bog on take off? (93civciv)
so this is not a bog issue it's an idle issue. if that's the case the idle surging is the fast idle under the TB.
Old Jan 5, 2006 | 04:26 AM
93civciv's Avatar
anything else i can try?
ttt!
Old Jan 5, 2006 | 07:06 AM
T3T495GSR's Avatar
If it is the Fast idle valve , its not hard to fix.
Its under the throttle body connected with 3 10 mm bolts and a coolant line.
First remove it and then you will notice there is a brass plate on one end of it. It is held on by two 5/16 bolts. Take those off, there is a plastic screw that most likely wiggled loose and it has a spring in between it . Make sure it is all attatched and tighten that plastic screw. Its a Flathead btw. Put it all back together and your idle should be fixed. I fixed mine. It used to idle at 1500 to 3500 up and down forever and it really messes up your driving. Just try and fix it because it is really easy
Old Jan 5, 2006 | 01:26 PM
93civciv's Avatar
Default Re: little bog on take off? (T3T495GSR)
yeah that was my problem back when i did the motor swap....my car only does this after i hit boost for a little bit..then it starts to do that.....thats why i thought it was a vacuum leak somewhere or even air in the coolant system...
Old Jan 5, 2006 | 05:14 PM
93civciv's Avatar
TTT....
Old Jan 5, 2006 | 05:57 PM
D@nnY's Avatar
why are you making runs in your nieghborhood?
Old Jan 5, 2006 | 06:12 PM
nsxmatt's Avatar
What is your setup? What fuel pump and such? Did you let the car warm up or did you just go hammer down on it right after you started it?
Old Jan 5, 2006 | 06:18 PM
93civciv's Avatar
Default Re: (nsxmatt)
well right now i do not have any upgrades on the fuel..cept for the fmu...but i do not think that is my problem....i let it run for like 15 mins before i took off...and i can go for awhile just fine and after awhile is when the idle starts
93civciv's Avatar
Default Re: (D@nnY)
big neighborhood....no insurance on the car...gotta play it safe!!
Old Jan 5, 2006 | 06:21 PM
nsxmatt's Avatar
Default Re: (93civciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civciv &raquo;</TD></TR><TR><TD CLASS="quote">well right now i do not have any upgrades on the fuel..cept for the fmu...but i do not think that is my problem....i let it run for like 15 mins before i took off...and i can go for awhile just fine and after awhile is when the idle starts</TD></TR></TABLE>
So your running 120psi of line pressure with a stock Civic fuel pump trying to add fuel. Chances are you did damage by getting greedy and wanting to boost around the block before you actually got the car finished.
Old Jan 5, 2006 | 06:50 PM
T3T495GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
So your running 120psi of line pressure with a stock Civic fuel pump trying to add fuel. Chances are you did damage by getting greedy and wanting to boost around the block before you actually got the car finished. </TD></TR></TABLE>
Matt knows his ****
Old Jan 5, 2006 | 07:37 PM
boosted k20's Avatar
Default Re: (T3T495GSR)
i would seriously do a compression check on that motor just to make sure u didnt blow anything.
cant believe people r still using FMU's
Old Jan 6, 2006 | 09:46 PM
93civciv's Avatar
my motor runs fine...compression is fine....just a lil idle prob...you dont have to make it a big deal..im looking for help not someone out to make me look like an ***....and yes i have an fmu...so what...i have no where to go right now...noone local can tune my car...i have not found anyone to chip and ecu for me and there are so many different engine managements out there i dont know which one to chose...
are you telling me upgrade my stock fuel pump...or could i just put on an inline pump?
Old Jan 7, 2006 | 07:12 PM
93civciv's Avatar
Old Jan 7, 2006 | 07:19 PM
SOHC_MShue's Avatar
i don't really see too much of a problem running a fmu setup as long as he keeps it at 5psi like it sais in his sig. Upgrading the fuel pump would be a good idea though.
Old Jan 8, 2006 | 02:50 PM
93civciv's Avatar
Default Re: (SOHC_MShue)
thanks at least there is someone on here who can believe in FMU's but oh well its in the trash..i just ordered an ecu chipped for my setup and bought a set of 310s
Old Jan 8, 2006 | 02:57 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civciv &raquo;</TD></TR><TR><TD CLASS="quote">thanks at least there is someone on here who can believe in FMU's but oh well its in the trash..i just ordered an ecu chipped for my setup and bought a set of 310s </TD></TR></TABLE>
Those 310's will be maxed out before you hit 5 psi, you should have checked before buying more parts. Nothing was wrong with the FMU, I ran one with alot of success but you have to be smart about it and do some research. Type in FMU in the search box and you'll find lots of info. You don't run a FMU without a inline fuel pump. The FMU works off of high line pressure, not lots of volume. A inline pump will provide the pressure where a intank will provide more volume, like in a larger injector and stock regulator type of fuel system. I actually ran both on my FMU setup to be safe and it never gave me problems.
Old Jan 8, 2006 | 03:55 PM
93civciv's Avatar
so your saying keep the fmu and run an inline pump?
Old Jan 8, 2006 | 03:59 PM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civciv &raquo;</TD></TR><TR><TD CLASS="quote">so your saying keep the fmu and run an inline pump?</TD></TR></TABLE>
He's saying buy some properly sized injectors.
Old Jan 8, 2006 | 04:00 PM
93civciv's Avatar
anyway to end this whole thing...i was looking for an answer as to why my car was ildeing like that...my title doesnt fit exactly what i was looking for...it was idleing up and down after i would boost and i found that the map sensor code was popping up and putting the ecu into crap mode causing my car to surge...got a missing link and fixed the prob
RinzEG6
Nov 24, 2014 12:02 PM
VTECwalka
Nov 4, 2012 06:58 PM
joelmatt89
13
Mar 9, 2009 07:03 AM
