leakdown tester
Old Mar 9, 2004 | 10:15 AM
Lei Siew Long's Avatar
Default leakdown tester
i'm in the market for a leakdown tester and ran across the snap on tester, but, for close $300.00 online, it's a little too rich for my blood.
is there another good, reliable, quality leakdown tester i can purchase for a lower price. if not, i just might bite the bullet and purchase the snap on one online.
Old Mar 9, 2004 | 10:53 AM
roydogg's Avatar
Default Re: leakdown tester (Hatch4urSnatch)
JCW or even summit has them for 60 bucks.
Old Mar 9, 2004 | 11:03 AM
Default Re: leakdown tester (roydogg)
thank you for the suggestion. i'm a little sketchy about the reliability of the tools on summit or JCW. anything other suggestions?
Old Mar 9, 2004 | 11:29 AM
Muckman's Avatar
Moderator in Chief
no, buy the summit. its not going to break unless u smash it.
Old Mar 10, 2004 | 03:46 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: leakdown tester (Muckman)
same way with the Jegs piece.........
$70........
Old Mar 10, 2004 | 06:52 AM
30psi Teg's Avatar
Default Re: leakdown tester (Mista Bone)
http://www.matcotools.com/Cata...30010
Heres a Matco one for $107
Old Mar 10, 2004 | 09:00 AM
Default Re: leakdown tester (30psi Teg)
thank you. i think i'll purchase the Matco one.
Old Mar 10, 2004 | 10:32 AM
Muckman's Avatar
Moderator in Chief
wtf? i guess you like wasting money. All it is, is two stupid pressure gauges. You could make it yourself out of Home Depot parts...
Old Mar 10, 2004 | 10:40 AM
raene's Avatar
I've been trying to myself, but unfortunately all the valves keep leaking... I'm thinking of picking up a kit myself just because the stupid valves leak + won't hold pressure Past 40psi the air starts seeping out from around the ****.
Old Mar 10, 2004 | 10:44 AM
FlamingEJ20's Avatar
there is a 44 dollar one on eastwood i think...just google it.
Old Mar 10, 2004 | 12:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">wtf? i guess you like wasting money. All it is, is two stupid pressure gauges. You could make it yourself out of Home Depot parts...</TD></TR></TABLE>
i appreciate the suggestion but, when i purchase tools, i want them to be a long term investment. so, i don't mind paying a little more for something more reliable and long lasting. Matco, has the reputation of being reliable and good tools so, i don't want to purchase something i can only use for a few years and throw away.
Old Mar 11, 2004 | 05:50 PM
raene's Avatar
Well, I returned my ghetto leakdown tester pieces and picked up the Tavia unit (it's identical to the Jegs except for the Jegs sticker), I'll let you know how it works shortly Damn this is making me nervous
*edit* I must say, I really enjoyed using the Tevia tester... so damn easy and everything seemed to be pretty high-quality about it
Cyl #1: 3.3% (rings)
Cyl #2: 4.5% (50% rings, 50% valves/other)
Cyl #3: 3% (rings)
Cyl #4: 4.5% (rings)
What do you guys think of these #s? The engine was warm, not hot, and I get between 210 and 220 between all cyls on a compression test.
Modified by raene at 8:09 PM 3/11/2004
Old Mar 12, 2004 | 02:40 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: leakdown tester (raene)
about average........
I had 20% on #3 for some reason once...........
Old Mar 12, 2004 | 08:05 AM
raene's Avatar
What's wrong with that, that piston looks fine... ly toasted.
Thanks Mista
Old Mar 12, 2004 | 10:03 PM
Mista Bone's Avatar
D Tranny Guru
even worse, I dropped in 4 USED Y8 pistons/rods without a rehone and the engine runs just the same!!!!!!!!!!!
friesx100
Suspension & Brakes
Jun 25, 2011 04:02 AM
racerxadam
Welding / Fabrication
Jan 9, 2009 11:08 AM
vtec_powah
Apr 16, 2006 08:24 PM
hondab1015
Dec 17, 2005 10:23 AM
themex77
May 20, 2005 08:11 PM
