Knock Threshold
Hello there Honda guys!
I have a fairly simple question:
At what point, for those of you with turbo'd motors (B16, B18, H22, whatever), do you begin to see knock? I would like to know in terms of boost, but I *also* need a bunch of other relevant information, listed below:
-What Motor?
-Compressor wheel?
-Intercooler?
-Compression?
-Injector Size / Fuel Pressure?
-Approximate flow of fuel under full boost at WOT?
-Wideband O2 value / A/F ratio (if applicable)?
-Maximum Timing Advance at WOT?
This is aimed at stock-blocked cars, but if you are not stock-blocked, please just list the mods you do have.
Thank you!
-What Motor?
-Compressor wheel?
-Intercooler?
-Compression?
Thank you!
Smarter than you
this is a hard question cause hondas can't just "see" knock. Its not like a DSM where u can just crank the boost until the ECU saves ur ***. Most of us on here tune our cars conservatively and are nowhere near the knock threshold. Usually when a honda motor sees detonation its already too late.
-What Motor?
b16
-Compressor wheel?
to4e 50trim
-Intercooler?
umm, yes? heh
-Compression?
10.2
750cc / 41psi
6-7ms, dont have my map avail.
11.8-12.1:1
24deg
This was on 91 octane @ 11psi, started knocking at 9,10,11. Set back to 20deg max timing.
b16
-Compressor wheel?
to4e 50trim
-Intercooler?
umm, yes? heh
-Compression?
10.2
750cc / 41psi
11.8-12.1:1
24deg
Smarter than you
LSturbo91 has a J&S knock sensor just fyi. he doesn't have to wait for audible knock like most of us would if we were trying to push the limits.
LSturbo: any reason as to why you're running such huge injectors if they're at less than 50% duty cycle at higher rpm's?
I realize that you guys cannot see knock, that is why I put up this post. I'm looking for the "safe" range to run a turbo'd B18A, but I don't just want numbers people pulled outta their butts. I'm looking for real-world info, ya know?
Anyone else who can chime in, I appreciate it!
The car I am working on will probably have a JS Safeguard eventually, too, but until then we're going to be tuning with a wideband O2. I'm thinking about 7-8 pounds of boost, and a A/F ratio around 11:1. We'll have to see what happens.
Also: on a stock ecu'd car with the distributor in the normal position, what kind of timing do you see at WOT? (I need an estimate of how much base timing to pull out for the car to run well).
Thanks guys.
Thanks guys.
Unfortunately knock doesn't happen at a certain boost level. It can happen at 4psi or 45psi. Knock is simply a measurement of detonation and the level at which it is seen is all dependent on tuning.
Smarter than you
Thanks guys.
Thanks guys.
9.2:1 compression.
550cc inj. @ around 60% duty cylce w/ 45psi base fuel pressure
a/f 12:1ish
total timing around 22 degrees
13lbs of boost
57 trim T04e intercooled.
no detonation on 93 octane.
I had 450's before and was pretty much maxing out at 10lbs, 45psi rail pressure about 80-90% duty cycle. So I decided to get these
blackeg
Engine Management and Tuning
Nov 15, 2015 03:42 PM
