Kinsler - BOSCH 044 Fuel Pump Setup
Old Sep 17, 2007 | 02:39 PM
Armaan's Avatar
Default Kinsler - BOSCH 044 Fuel Pump Setup
I've searched, and seen some pretty clean setups, namely, Art's. But I don't want to cut my stock fuel tank and install the Full Race style sump.
Anyone else out there in the same boat? The Kinsler/Bosch 044 pump will NOT fit in the stock location.
Top view of the fuel tank (90-93 Integra RS):
Close up of fuel pump door:
Kinsler setup:
Kinsler pre/post inline fuel filters:
Kinsler/Bosch 044 pump:
Old Sep 17, 2007 | 10:19 PM
tony413's Avatar
Default Re: Kinsler - BOSCH 044 Fuel Pump Setup (Armaan)
just run your stock pump to feed the bosch 044 or sense the bosch is a pull type cut a hole weld a bung and run lines to the pump
Old Sep 18, 2007 | 12:47 AM
Redline130's Avatar
Default Re: Kinsler - BOSCH 044 Fuel Pump Setup (tony413)
I don't think using the stock pump to feed the Bosch pump is a good idea. The stock pump will become a restriction as it will not flow as much as the Bosch pump will.
I had a 1/2" stainless tube welded on the stock fuel pump bracket and bent parallel to the bracket that the stock fuel pump sits on. On top of the fuel pump bracket, I had a steel -8an bung welded on. Then I just mounted the fuel pump and inline filter and made the necessary lines.
Old Sep 18, 2007 | 12:56 AM
SwappedTURBOegg's Avatar
he might be talking about a surge tank setup. that wouldn't be a bad idea.
Old Sep 18, 2007 | 04:45 AM
Turbocivic94's Avatar
you dont have to mount the pump inside the tank. Just run a tube into the tank with mustang sock...
Old Sep 18, 2007 | 06:14 AM
.CUBISH.'s Avatar
Default Re: Kinsler - BOSCH 044 Fuel Pump Setup (Turbocivic94)
ive made over 700hp with a 255 intank feeding a bosch pump
Old Sep 18, 2007 | 06:47 AM
tony1's Avatar
Default Re: Kinsler - BOSCH 044 Fuel Pump Setup (.CUBISH.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">ive made over 700hp with a 255 intank feeding a bosch pump</TD></TR></TABLE>
I made 650whp on E85 with this setup, which is the equivalent of around 800whp on gas.
Old Sep 18, 2007 | 06:53 AM
.CUBISH.'s Avatar
Default Re: Kinsler - BOSCH 044 Fuel Pump Setup (tony1)
quick question...did you have a -8 coming from the tank to the bosch....and did you still use stock lines?
Old Sep 18, 2007 | 06:58 AM
tony1's Avatar
Just mounted in between the oem filter and the fuel rail. Stock lines up to the filter.
Old Sep 18, 2007 | 07:02 AM
Axle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
I made 650whp on E85 with this setup, which is the equivalent of around 800whp on gas.</TD></TR></TABLE>
Was this on a typical street B18?
.CUBISH.'s Avatar
nice.. i had mine near the back... -8 feeding it...then the rest was stock stuff
Old Sep 18, 2007 | 07:56 AM
tony413's Avatar
i run a similiar set-up i have the bosch 040 intake feeding the bosch 044 inline its pretty godly and was cheaper than a Aero eliminator
to op look here : http://www.sillbeer.com/images...4.jpg
or
http://users.adelphia.net/~nuk...2.jpg
Old Sep 18, 2007 | 08:02 AM
so you can run the bosh as an inline pump and make good numbers? what size line from the 255 to the bosh?
Old Sep 18, 2007 | 08:04 AM
.CUBISH.'s Avatar
Default Re: (SwappedTURBOegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Just mounted in between the oem filter and the fuel rail. Stock lines up to the filter.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">nice.. i had mine near the back... -8 feeding it...then the rest was stock stuff</TD></TR></TABLE>
Old Sep 18, 2007 | 08:10 AM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">so you can run the bosh as an inline pump and make good numbers? what size line from the 255 to the bosh?</TD></TR></TABLE>
just a single bosch 044 is good for over 650whp on gas
Old Sep 18, 2007 | 08:11 AM
Default Re: (.CUBISH.)
wow thats kinda neet the inline thing.
Old Sep 18, 2007 | 11:06 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">just run your stock pump to feed the bosch 044 or sense the bosch is a pull type cut a hole weld a bung and run lines to the pump </TD></TR></TABLE>
there are lots of buicks running 10's with a setup like that, a modern muscle 40gph (basically a walbro) pump feeding a bosch 044. i ran mine in parallel, but there are lots of series setups. sooner or later the bosch will draw through the intank, its not as big of a restriction as everyone thinks.
Old Sep 18, 2007 | 12:38 PM
XES's Avatar
XES
Default Re: Kinsler - BOSCH 044 Fuel Pump Setup (boostedcivicsir)
Are you guys redoing any of the stock fuel pump wiring to larger gauge and also running relays to each (intank + inline)?
Old Sep 18, 2007 | 01:07 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
there are lots of buicks running 10's with a setup like that, a modern muscle 40gph (basically a walbro) pump feeding a bosch 044. i ran mine in parallel, but there are lots of series setups. sooner or later the bosch will draw through the intank, its not as big of a restriction as everyone thinks.</TD></TR></TABLE>
exactly
stock pump feeding the bosch is not a problem
i just went with the bosch feeding a bosch because i may want to go over 800hp easy just need 4 more injectors and super big turbo to do it
Old Sep 18, 2007 | 07:45 PM
Armaan's Avatar
Thanks for the responses. I'm starting to lean towards the Full Race sump setup....just gotta figure out how to run stock lines from the sump to the rail. I'd like to retain the stock lines...no need to run bigger lines to the rail.
Old Feb 3, 2009 | 04:45 PM
civic-r11's Avatar
i am just wanting to see the Bosch fuel pump in the engine bay.. according to some people that is where they put it.. i am just wondering where i should install it.. cause i don't want to run it all the way back by the fuel tank... sry for the noob question.. i am new about modding my fuel system... i have a walbro 255 and i am t going for 550 plus and i don't want to run out of fuel.. i am lost in where to install it..
thanks
Old Feb 3, 2009 | 06:04 PM
Bailhatch's Avatar
Where is everyone getting their fittings for the 044? What type of washer/gasket did you use?
Old Feb 3, 2009 | 08:53 PM
Boosted_B_Series's Avatar
In between the factory fuel filter and fuel rail.
Old Feb 4, 2009 | 02:02 AM
Tony the Tiger's Avatar
With an inline Bosch pump pulling the fuel through a Walbro + surge tank, the Walbro is literally running at 0 PSI.
If you check the flow rating, a Walbro 255 LPH is rated at 40 PSI... If you chase the flow curve of a Walbro down to 0 PSI, it flows well over 300 LPH and already indicates that is well enough for 750-800 WHP.
That's why inline pumps work, and it's not really a restriction as most people think. When we speak of huge -AN lines, guys like to go -8AN, -10AN, etc.. it's complete overkill when we all know that a single -6AN line can literally support over 1000WHP. I've already done 908 WHP on a single -6AN line on my Supra, and base on the fuel demands of a 2JZ motor, that's close to a 1000WHP on a Honda. If a -6AN line can support that much power, imagine a 5/16" diameter inlet/outlet of a Walbro pump just free flowing is really no restriction at all.
Old Feb 4, 2009 | 05:12 AM
tony1's Avatar
We have everything here as well as full install kits to put it between the filter and rail. You need a copper crush washer for the inlet side and the pump comes with one for the outlet side.
