just a word of advice...................
Old Jun 4, 2003 | 11:49 AM
intekragsr's Avatar
Default just a word of advice...................
NEVER buy a used timing belt tensioner.
I did this and my brand new JG pro series head is toast
The belt skipped 5 teeth and bam...
All the valves are bent and I have yet to find the damage to the new pistons.....
Just a little rant and and caution to future engine builders.
Modified by intekragsr at 9:16 PM 6/4/2003
Old Jun 4, 2003 | 11:52 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: just a word of advice................... (intekragsr)
Damn... Sorry to hear it.
Ill try to keep that in mind.
len's Avatar
len
In fact, don't ever buy used parts period. You don't know how much life it has left. Buy new ones from me.
Note: Used engine component parts that is considered a wear item like timing belt, water pump, oil pump, oil seals. I wouldn't recommend anyone buy used cam seals.
Old Jun 4, 2003 | 01:32 PM
Trigun's Avatar
damn kyle you have GOT to be kidding me. did you just not drop your new motor in? is your car EVER going to run again?
Old Jun 4, 2003 | 01:53 PM
intekragsr's Avatar
Default Re: just a word of advice................... (Trigun)
hehe this is my third motor soon to be 4th maybe...
Old Jun 4, 2003 | 01:58 PM
alpha's Avatar
The extra $40.00 would have saved your head =/ How much did you pay for a used tensioner?
Old Jun 4, 2003 | 02:03 PM
intekragsr's Avatar
Default Re: just a word of advice................... (0x64)
40 bucks :/
Ive learned my lesson. No more used parts, EVER.
Old Jun 4, 2003 | 02:13 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: just a word of advice................... (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">In fact, don't ever buy used parts period. You don't know how much life it has left. Buy new ones from me.
Note: Used engine component parts that is considered a wear item like timing belt, water pump, oil pump, oil seals. I wouldn't recommend anyone buy used cam seals. </TD></TR></TABLE>
I agree. Len can vouch for me and say everything on my new rebuild is new, with the exception of the sensors. I didnt have to but I even went as far as buying some new bolts in some areas of the car. Every hose, gasket, seal on my car is all OEM brand new. Even the spring tensionor is brand new on my car. It cost alot, but it'll be worth it.
Plus, len is the guy to go to for OEM honda-parts.
art
Old Jun 4, 2003 | 02:15 PM
legendboy's Avatar
Default Re: just a word of advice................... (Arturbo)
ooo I just sold a tensioner to someone a couple months ago, hope he doesn't have any problems
Old Jun 4, 2003 | 02:25 PM
alpha's Avatar
You live and learn. Good luck with your next build if there is one
Old Jun 4, 2003 | 03:59 PM
MiraiZ's Avatar
yup...replaced almost everything under my hood when it was rebuilt...especially the timing belt (despite the fact that it still had less than 10k miles on it)
Old Jun 4, 2003 | 05:34 PM
phase12gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">No more used parts, EVER. </TD></TR></TABLE>
I agree with you 100%! to USED parts. Everyone should buy new parts if possible and save yourself the headaches in the future.
Old Jun 4, 2003 | 05:41 PM
rjardy's Avatar
Sorry to hear that. If I was home I would help with the rebuild but im not. 10 days though WOOT!!
Rob
Old Jun 4, 2003 | 05:52 PM
Prelude Vtec 23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">Ive learned my lesson. No more used parts, EVER. </TD></TR></TABLE>
Sometimes we just have to learn from experience.
Old Jun 4, 2003 | 08:08 PM
95c1v1cs1's Avatar
Default Re: just a word of advice................... (Prelude Vtec 23)
sorry to hear. good luck with it all.
Old Jun 4, 2003 | 08:11 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: just a word of advice................... (95c1v1cs1)
**** when i rebuild mine i dont re use **** from my own motor. i run all new timing belt, upper and lower gasket kits etc.. sorry to hear about your motor!!
Old Jun 4, 2003 | 09:43 PM
tony1's Avatar
Default Re: just a word of advice................... (MotorMatrix.com)
I agree, it's always better to use new parts, but whoever built the engine should've noticed that the belt wasn't tight enough. Once the tensioner is locked down it won't move. If the belt slipped then it wasn't tightened right to begin with...
Old Jun 4, 2003 | 11:12 PM
ninesecrx's Avatar
Default Re: just a word of advice................... (tony1)
I have to agree with Tony on this one. I personally dont think the tensioner itself did this.
Old Jun 4, 2003 | 11:15 PM
Foozball26's Avatar
Default Re: just a word of advice................... (ninesecrx)
yea ditto on the last couple posts, I crank down on mine and have a hard time getting it off..I know mine is good
Old Jun 5, 2003 | 12:53 AM
Rob Dizzle's Avatar
Default Re: just a word of advice................... (Foozball26)
there are still retards out there that buy napa timing belts and re-use as much **** as possible
i have bought used cam gears and whatnot, but everything new for the other parts.
you sometimes just need to learn first person perspective to understand why people buy new parts because your cheap or used part is toast and cause damage to your motor
Old Jun 5, 2003 | 12:58 AM
AlLMoToRvOtEr's Avatar
Thats shitty but it shouldn't slip weather it's used or not as long as it was tightened properly.
Old Jun 5, 2003 | 06:26 AM
SEFIxCivic's Avatar
i have a bunch of reused parts on my motor. no problem here. i guess it helps if the motor you start out with is under 20 k miles tho. its all about using your common sense, and giving yourself an honest assestment of what types of jobs you can handle on your own. if not prepare for a learning experience or more accurately a learning expense.
Old Jun 5, 2003 | 09:40 PM
Downey's Avatar
i dont think it was the tensioner. since the head was milled so much, the timing belt turned out to be a little bit to long which caused it to jump.
sorry to hear about all the problems Kyle. let me know if theres anything we can do.
Old Jun 5, 2003 | 09:47 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: just a word of advice................... (Downey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">i dont think it was the tensioner. since the head was milled so much, the timing belt turned out to be a little bit to long which caused it to jump.
sorry to hear about all the problems Kyle. let me know if theres anything we can do.</TD></TR></TABLE>
Good point! Kyle, sorry to hear about this.
Old Jun 5, 2003 | 09:49 PM
tony1's Avatar
I don't think you can mill a head enough to make the belt too long. There's quite a bit of adjustment in the tensioner.
