Just went closed DP..
Old May 15, 2002 | 05:54 AM
92HB_HB's Avatar
Default Just went closed DP..
yesterday , i converted to closed downpipe, took about 2.5 hrs.. but the results are pretty good.. I've gotten sick of the wastegate sound being the only noise people hear when i'm at full throttle.. now they'll hear the spooling turbo and BOV a bit more.. next on the list, quiet the exhaust a bit more.. Geezz, close downpipe sounds so much better, i can also hear the wheels break loose now, when before i thought it wasn't happening cuz of the darn wastegate noise... give it a THUMBs UP on the 2-do-list..
Old May 15, 2002 | 06:05 AM
VTC_CiViC's Avatar
Default Re: Just went closed DP.. (92HB_HB)
Are you saying you went closed DP or closed wastegate?? Sounds like your talking about the WG.
BROOD's Avatar
Default Re: Just went closed DP.. (VTC_CiViC)
I'm sure he means a closed loop wastegate.
92HB_HB>>did you notice any power difference going open loop wg to closed loop wg?
[Modified by SLPR, 7:06 AM 5/15/2002]
Old May 15, 2002 | 06:35 AM
Teg4e's Avatar
What's your turbo setup and at what psi? What wastegate do you run?
Old May 15, 2002 | 02:28 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default How much HP?
How much HP do you think you lost? What size DP and exhaust are you running?
I am contemplating ADDING an open wg, not changing one back hehe.
Did you ever try a lawn mower mufler on it to quiet it down? Or even routing the dump tube further under the car so the sound wasn't coming right from hte engine bay?
- Slater
Old May 15, 2002 | 04:48 PM
92HB_HB's Avatar
Default Re: How much HP? (b16a5gracer)
opps, i meant closed WG.. didn't really notice any power gains nor losses either.. but the sound is so much more pleasing.. i've been running aboug 7-9 psi on the streets on a t3t4b..
my DP goes from 2.5 at the turbo then merges into 3" under the oil pan and all the way out back.. not running any mufflers, just a resonator out back..
brad98_teg
Sep 19, 2006 05:42 AM
ITR-T-GUY01
Nov 4, 2005 01:12 PM
twkdCD595
Sep 29, 2002 10:43 PM
MyWhiteCivic
Sep 21, 2002 12:36 PM
Damon B.
Nov 27, 2001 01:25 PM
